DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.28.2008, 12:48 AM
Would anyone know how much extra run time I would get running a 4S 5000 comparied to a 5S 5000?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
MetalMan
MetalMan's Avatar
05.28.2008, 12:53 AM
Assuming you gear them both for the same top speed (and thus use the same throttle input), you should gain 25% runtime. So if you get 15mins on 4s 5000, you'd get almost 19mins on 5s 5000mah.
But if you keep the same gearing, you might end up with the same or slightly less runtime (depending on if you changed your throttle control or not with the higher top speed).
tc3_racer_001
tc3_racer_001's Avatar
05.28.2008, 01:24 AM
havent heard many good things with those extreme lipos... the flying guys are dissapointed in them.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
DRIFT_BUGGY
05.28.2008, 02:11 AM
I thought that was the 1st series and the V2's are one of the best packs on the market?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
05.28.2008, 03:55 AM
yes, i may be wrong, but the bad ones were great for 50 or less runs then pretty much useless...
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
05.28.2008, 10:12 AM
Had my Hyper 8 geared with a 16T pinion a while back and it was waaayyy too much for a small track.
Now I get about 30ish minutes of runtime with dual MA 8Ah 2s packs, 1512 2d/f, geared for around 45mph (14t pinion) and it is quite fast and still has tons of torque. Temps are very good too. Actually, it's almost too torquey for a small track geared at 14T.
skellyo
skellyo's Avatar
05.28.2008, 06:26 PM
I believe it may have been the RC Pro series that went with a 4S standard for electric 1/8th. I don't know that for sure, but I seem to remember reading that on rctech.net.
DRIFT_BUGGY
05.28.2008, 06:45 PM
I'll just be doing club racing (probably against nitros) so nothing to serious. Just got to find more info on the TP V2 Batteries and if it is worth spending $45 more on a 5S over a 4S
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
skellyo
skellyo's Avatar
05.28.2008, 06:52 PM
My guess is that they went from 20C to 25C cells or some small change like that. They use Enerland cells, so I wouldn't hesitate to use them myself.
VintageMA
VintageMA's Avatar
05.28.2008, 07:14 PM
I just bought a bunch of TP V2 packs and my initial impressions are very good. My TP V2 5S 3850 keeps up just as good as my 5S Neu 3900 pack. No idea on longevity yet as they are all less than a month old.
Also picked up some 6S TP V2 2600 packs for when my XB8 when my 1512 3.5D Neu comes in.
“Everyone has a right to be stupid; some people just abuse the privilege.”
DRIFT_BUGGY
05.28.2008, 09:04 PM
Yeah the TP 5S 5000 is pretty much the same price as the Neu 5S 5000 but I have $400 credit at Amain that I got to use up but still don't want to use the $400 on crap batteries that don't last. No-one has the Hyperion Adaptor to TP balance tap, how long could I run the batteries till they need to be balanced?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
VintageMA
VintageMA's Avatar
05.28.2008, 10:33 PM
Try here for balancers:
http://www.rclipos.com/Balancers.htm
DRIFT_BUGGY
05.28.2008, 11:52 PM
Sweet, thanks, free world wide shipping to
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
Motoman
Motoman's Avatar
05.29.2008, 06:11 PM
The TP Extremes are one of the best batteries I've seen. In fact the past 2 weekends in a row I went out to the track and have been driving my X-1 CR on an approximately 1.5 year old Extreme V1 3s 25C 2070 pack and it runs fine. The only problem with that setup is that the battery is too small both in cells and capacity. But, it's just to test the buggy and it gets me about 10 min. After I run that battery to the 9v cutoff it's a little hot but it stays balanced throughout the entire charge period.
The other battery that I ordered will be a lot better suited for the job (TP extreme 6s 3850). I figure I should get around 45-60 minutes with that pack.
Heli guys swear by Thunder Power's Extreme lineup including myself.
tc3_racer_001:
Who told you the Extremes were bad batteries?
DRIFT_BUGGY
05.29.2008, 06:16 PM
tc3_racer_001:
Thanks for posting that up
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
