Serum
Serum's Avatar
02.08.2005, 03:56 AM
YEAH! that's about the same setup as i have got in mind!, i have got 4 shocks, instead of 8 (ofna 9.5 (UE)) with the racer X suspension you have! I will get the GA 6061 bulks, with the UE 8 spider. (just to be save) and a set of GA ti skids..
I like the CF g-maxx frame! how is it handling? Why are your tires mounted wrong?
i have got a small micro movie of my bigmaxximum on my savage,
on 16 cells (got more movies of it though) here it is..
ryanvm777
02.08.2005, 04:42 AM
I just got the shocks and susp. and still putting everything together. I just put the tires on for the picture. The carbon fiber chassis is great. With over an inch longer it really helps keep the front end down. The chassis weighs practicly nothing. I did blow out my spyder gears inside the allum diffs, but I think it was because they were not shimmed correctly. The 7xl with 18 batt. is really powerfull. Once I get it all together again I will be able to tell if the diffs hold up with it shimmed correctly.
Serum
Serum's Avatar
02.08.2005, 08:01 AM
It looks GREAT!
you have got the ext. version of the g-maxx frame?
I did a little math, ican buy te UE diffs for 244 dollars.
If i buy the stockdiffs with aluminum diffcase, it would be also about 250 dollars.. So i think it is more interesting for me to buy the UE's. I saw you bought your ' stock ' diffs for a nice price..
have you got more pics of your project? What bulks are you using? How much does it weight?
Thanks!
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
02.08.2005, 09:42 AM
His tires are on right in the picture. The rear upper arm is mounted backwards, though. You can get the diff cups and aluminum cases for around $150 here. Then you just need the spider gears (around$5 per set) and your diffs are set. Ryan runs the Integy version of the racer-x suspension, as well as Integy type II bulks, RD Logics cvds, Maximizer cups inside aluminum cases (bought these used) and a few other goodies.
Serum
Serum's Avatar
02.08.2005, 10:12 AM
Those tires are made to eat the sand, not the other way around... (correct me if i am wrong but they are mounted wrong, for real......)
Well, for that last 60-70 bucks, i choose the 8-spiders.
RC-Monster Mike
Site Owner
02.08.2005, 10:20 AM
After a second look, you are absolutely correct! The tires are on backwards (and so is the rear upper arm). I am going to carry the Fastlane Hybrid bulks and should have them in by the end of the week. I think the Hot Bodies buggy hardened gears should fit in them, and they are pretty inexpensive. You can't go wrong with the UE stuff, either though.
HotnCold
HotnCold's Avatar
02.08.2005, 04:18 PM
wonder how it would run with the upper rear arm reversed?? - wonder if it makes a difference?? - couldnt the tires be corrected by switching sides? :)
Hows that "Hope and Change" working out for Ya???
Serum
Serum's Avatar
02.08.2005, 04:25 PM
It doesn't matter that much (the rear suspension).. My UE doesn't bind when mounted wrong..
And yes, those tires are right, when mounted on the other side.
I smell a lightning pro in your sign!
HotnCold
HotnCold's Avatar
02.08.2005, 04:32 PM
Mighty good sniffa ya got there....
Daniel Murray
02.09.2005, 10:25 PM
I hope they make some parts for the Tamiya TNX.Fastlane parts look alsome !!!!!!!!!!!
wheeliE-maxx
04.23.2005, 10:32 PM
Originally posted by Serum
Are those RDlogics cvd's any good? (running offtopic to the Fastlane subject now) can you also get MIP shafts?
Some guys on the Traxxas forum have broken RD Logics cvds on stock Titans on 12 cells.
RC-Monster Mike
Site Owner
04.23.2005, 10:38 PM
There is a user on this forum running 18 cells through a 7xl motor with the RDLogics cvds. He blows diffs, but not cvds. I suppose it is safe to assume that there is a lemon or so for every product out there. The RDLogics cvds are beefier than the MIPs, and likely stronger as well.
RC-Monster Mike
Site Owner
04.23.2005, 10:40 PM
The RDLogics cvds can't be used with 1/8 diff, though, which is unfortunate. They are similar in design to the dynamite cvds in that they have a shorter bone and longer drive cup.
wheeliE-maxx
04.23.2005, 10:45 PM
Very true about the bad thing in every product. In the UE VBS, the rear has some caster to it in the back for anti-squat. Do the FLM combo bulks have any special geometry like that?
RC-Monster Mike
Site Owner
04.23.2005, 10:47 PM
No. Stock geometry. No anti squat like the UE.
