hailmick
07.27.2008, 02:41 AM
If you are running an external BEC try disconnecting that and running a receiver pack to eliminate the external BEC as the problem. The other thing that could be possible I suppose is the steering servo going bad and creating some sort of interference int he signal of the whole system, but I think the BEC is the more likely culprit.
I had a similar issue with a bad steering servo. As I pulled the throttle the servo would twitch a lot and stay off center. It did not casue any issues with the control of the esc though.
Try a rec pack, and make sure it is fully charged, a pack with low voltage will cause all kinds of problems...
try switching your steer servo out like the boys above have said
my buggy has a twitching steering servo but its a nitro its even worse when steering
Patrick
Patrick's Avatar
07.27.2008, 12:09 AM
Do you have a second spectrum receiver to try? I've heard of something inside the receivers coming loose occasionally, maybe that could me making it act strange?
I've been using a DX3 with a quark 125 for about a year and a half, but I've never had any sort of glitching issues.
brushlessboy16
brushlessboy16's Avatar
07.27.2008, 01:31 PM
are you running UBEC?
Trick440
07.27.2008, 01:54 PM
Not running a BEC.
It looks like the problem was a brand new Hitec. I only rode on this new servo a few times. I put the a stock revo servo in and its all good. Alot weaker steering but she runs....
I'm off to BaSh!!!
brushlessboy16
07.27.2008, 02:08 PM
wooohoo, i dunno if i helped but..Glad to be of assistance
