07.24.2008, 01:31 AM
The 36mm tekno mount I have has the 4 m4 thread holes placed in a square pattern, 34mm apart on both sides. If the slots for the nitro mount line up with those specs, then you should be able to use it. Problem is that it will sit too far back from the spur, unless you use the tekno clutch adapter and a clutch setup to make up the space.
Mozzy
Mozzy's Avatar
07.24.2008, 02:09 AM
Originally Posted by jayjay283 View Post
I had been debating the tekno mount for the LST2. I was waiting for the 40mm mount to be available, but they dont sell the adjustable motor mount plate option, so it wouldn't it be just another unadjustable stationary mount. ?
Note: Tekno RC V3 Motor Mount Plates (TKR40002, TKR40002A) not included and are not required. Your application may vary and the motor mount plates may make it easier to adjust gear mesh.
That really depends, if you're still using the 2 speed clutchbell type setup & the gears line up nicely next to the spurs all that the mount would need to do is slide from back to front (of the truck) to adjust the mesh. Just like the nitro motor mount does.
The nitro motor mount doesn't move any other way apart from the forward/backward movement up to the transmission & to & from the tank.
I know a guy here that bought one & I want to see if it'll suit my truck & clutch set up. If so, giddyup(!!), I'm buying one.
By the way, is there a pic of these plates?
I just measured the screw holes from the nitro motor mount still mounted to my motor & they are not even close to being the same distance. Maybe these plates will solve that issue??
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
jayjay283
jayjay283's Avatar
07.24.2008, 01:38 AM
34mm would work.. clutch huh, so many options yet so limited lol
captanabolic
captanabolic's Avatar
07.24.2008, 11:55 AM
Im hoping to have one of these to test these weekend. With a Neu 1515 1y in my lst2. The guy I am getting the mount from is one very smart DUDE.
http://captanabolic.onestop.net/drift_manga.gif
FAST ENOUGH TO DO SOMETHING STUPID
REALLY STUPID
THE CAPT IS SOOO SEXY!!!
HOLY HOLE IN THE DONUT BATMAN!!!
07.24.2008, 12:41 PM
Let us know how that goes. I was going to make my own mount for the aftershock, but time is always against me...
TexasSP
Something, anything, nothing
TexasSP's Avatar
07.24.2008, 11:59 AM
That is slick! This Dude needs to get with Mike about selling these on RCM. That would be an awesome compliment to Mike's already nice array of conversion parts.
www.cubicle101.com
jayjay283
jayjay283's Avatar
07.24.2008, 12:54 PM
Yeah the dude is who I was talking about in my 1st post, didnt want to come out and say it. His mount will be sick, and the 1 speed hubs are great. Theres 5-10 conversions going on just here another 10-20 on that site. Mike needs to make stuff like that or get into an lst2 conversion collusion with him !!
Chapito
07.24.2008, 04:07 PM
Yeah, just to clarify for everyone, I'm one of Mike's biggest fans and always recommend purchasing from him first. If he had an LST motor mount or one speed hub I would already have ordered one from him. As far as I know, TDR racing(TheDude) is the only one making the Hub and developing a mount; just sharing the knowledge.
mind made up
lind5
mind made up - 07.24.2008, 05:14 PM
ok guys well i have decided to go with the lst rather than the muggy
i have orderd the impakt rc motor mount and mikes 2 speed adapter
i will probably fab my own battery tray i will try the motor mount out but will probably have t fab some thing up to get it to work right but when it all turns up i will let you no how it went and get some pics up for ya to check out
cheers for ya advice
now i just have to weight
dudes engine mount
lind5
dudes engine mount - 07.26.2008, 04:27 PM
hi guys had a look at my truck now thinking that the engine mount fron impakt wont fit has anyone tried the motor mount that dudes made on a lst yet and the single speed gear hub
whats the quality like
ease of use
ease of mounting
cheers
gogglespaesano
gogglespaesano's Avatar
07.26.2008, 07:10 PM
the motor mount isn't out yet, The Dude uses the Captain as a tester, that is why he is expecting one. Otherwise I have one of his single speed hubs and they are great. Definitely recommend it.
captanabolic
07.31.2008, 11:42 AM
Ok I got the motor mount installed did not have time to run it. Fit and finish were nice bet the production model will be sweet. The dude and I were worried about bracing the larger Neu motor. I can honestly say that I do not believe a brace is necessary. It took quite a bit of force to get the motor and the mount to flex. It fit perfect in the mounting locations and some 4mm button heads to secure it to chassis. It is very rigid. The swivel action is a great feature for setting the gear mesh. So far overall looks like it will be another homerun. I am going to use plastic spurs this weekend so I can tell if the motor mount is flexing causing funny spur wear. Here are some quick pics of it mounted up. gonna have to do some creative work to get the gear cover on. LOL
REALLY STUPID
mickeymoose
07.31.2008, 10:54 PM
Here's one I built with an E-Maxx tranny. AS long as you do all the upgrades to the tranny ( upgrade pin on input shaft gear, steel idler gear, and gorilla maxx drive adapter ) it works great. Here's a couple of pics.
http://i68.photobucket.com/albums/i2...splates007.jpg
http://i68.photobucket.com/albums/i2...splates008.jpg
http://i68.photobucket.com/albums/i2...splates005.jpg
http://i68.photobucket.com/albums/i2...splates002.jpg
http://i68.photobucket.com/albums/i2...e_1/truck3.jpg
http://i68.photobucket.com/albums/i2...e_1/truck2.jpg
lind5
08.01.2008, 10:59 AM
hi mate i was gonna try do something with my chassis but what you have there looks ideal any chance on some info on where i can get one like that or did you make it your self
what spur and pinion you running on that
TexasSP
TexasSP's Avatar
08.01.2008, 11:33 AM
That maxx-tranny job looks factory. Nice job on it for sure.
I think there is an excellent market for someone who comes out with a nice lst/lst2/aftershock electric conversion kit.
www.cubicle101.com
