- feagio L rotor (burnt the windings)
- feagio XL rotor almost new (also burnt the windings)
- 3.5 mm connectors brand new
- 4 or 5 never used standard servos.
- GS racing TGF 2 radio and reciever brand new
-Proline 2.2 moabs on wheels (two of the wheels are junk but tires are like new if you can get them off)
i was told they would still be good, i directly shorted the windings with both of these motors , the xl's wires rubbed the chassis till they were bare and shorted it, and the 9L i put too long of motor screws in and it was shorted across the mount.....both dumb mistakes equal HOT esc and hot motor very quick, which shut it all down but i dont think they got hot enough to demag.
i dont have more cans to test either in, but if some one has a spare can they could give them a try...
you don't need to post 3 - just post what you have and take what you need - the idea is to stay balanced...
BENSF has a TQ3 rx/tx...
Sorry to take but it is not for me - I'm building this into something for a friends 7 year old for his xmas pressie from his dad - I have most of the pede/rustler spares but am in need of:
- Brushed ESC
- Brushed Motors
- RX/TX with crystals
- front wheels
I will happily pay shipping and send/post unwrapping pics... Please could you PM me if you can help...
i can help you i have a am ofna radio with reciever and crystals. i also have some brushed motors. the need brushes and springs but i have about 5 of them. you pay shipping for usps flate rate box and there yours
New-1 Pair Proline Velocity 6 40 Series Wheels
New-2 Johnson 550 Sized Electric Motors (basically equal to the traxxas titans for e-maxx)
Used-Posi-trac differential for e-maxx shimmed and greased (older 3906 diff ring gear and case)
New-Stock E-maxx tires from 3906 maxx
-Tamiya tl-01 roller w/ tires and steering servo. Just need body, esc, motor and radio. 2 other parts cars go with it (could probably be combined to make another roller).
-crt .5 yellow dish wheels with losi bk bar tires. Tires are worn.
-Nitro parts. Fuel tanks for Muggy, Duratrax raze, and Cen Matrix. Pipe for Cen matrix.
- 9xl with broken rotor
- 2.2 wheels for a CRT.5 - The ones that don't use hex's...
- 3.5/4mm bullets
- GTP pipe
TakeDown
- A never used 27mhz 2ch radio "Futaba" with receiver.
- Two packages of reusable large zipties.
- A 75mm comp fan
- Some micro-t spares.
- Spare 30cc pipe "bought a better tuned one and its on its way".
- Micro-t stock charger. "needs plug".
Trev3813
- hot bodies HR-3 AM 27 Mhz 2 CH Receiver, works great, compact,
- Airtronics 92721 27 2 CH AM Receiver, works good, compact
- Duratrax RX-100 AM 2 CH Receiver, out of a vendetta works good
BenSF
- CRT.5 Nitro parts
- 3 female 6mm connectors
- traxxas 3ch radios and receivers(in varying condition. TXs are okay receivers need new antenna.)
SuicideNeil
- CRT.5 Nitro parts
Rootor
- micro-t stock tires on yellow wheels
- few different reciver boxes off nitros
-9v 200ma charger/power supply
-stock mlst2 aluminum shocks
-couple sets of losi springs, i know there are 2.6, 2.9, and another rate i idunno
Cheesecake
- airtronics 94737 servo wires were repaired but it works
- ofna am radio with reciever and crystals
TexasSP
- New-1 Pair Proline Velocity 6 40 Series Wheels
- New-2 Johnson 550 Sized Electric Motors (basically equal to the traxxas titans for e-maxx)
- Used-Posi-trac differential for e-maxx shimmed and greased (older 3906 diff ring gear and case)
- New-Stock E-maxx tires from 3906 maxx
- 1 Damaged Novak HV Brushed Controller 16.8 volt capable
Kona
