jnev
jnev's Avatar
10.10.2008, 07:33 PM
Your buggy is looking great! Thats good to hear that the Kyosho motor mount fits well. The D8 shouldn't be too hard to convert after all. You took a picture from the side of the receiver box and motor mount, but its a little hard to tell if the pinion will fit. Is there enough room for it or is it a little too close for comfort?
ffactory666
10.10.2008, 10:19 PM
Looking great dude didn't even notice that you started your build until i posted my start today.
Looks like we did similar things to the receiver box .
Jnev the box has to be cut to allow for the pinion and adjustment for the gear mesh , you can see pics of this in my D8 Corr truck thread .
FG101C what pinion are you going to run with that set up , i'm going with a 17t with my 5s 1600kv motor set up .
rootar
rootar's Avatar
10.10.2008, 10:44 PM
move your battery tray all the way to the front, not the rear, it will handle MUCH better over the rear mounted battery.
Looking good! if i could get a 2nd buggy and itd be a D8, they are supposed to be incredibly easy to drive and very forgiving.
FG101C
10.11.2008, 02:16 AM
I plan on running a 13 tooth pinion on 4s 6000mah, 2200kv. Trying to make 20 minute mains. With my 8-T I get exactly 20 mins with a 10 tooth 4s 2200kv. That is until my driving gets smoother and maybe I can squeeze out a little more.
The fit between the pinion and box is tight, I will figure all the little details out once I have everything.
Cain
10.11.2008, 10:43 AM
if going for 20 minute mains, maybe go with the 1512 2.5D 2050kv motor.
FG101C
01.06.2009, 06:49 PM
Took the pictures after I drove this, runs good on the track. Using a Medusa 36-60 2000kv, Hyperion 4350mah 5s pack. Still working on getting the gearing just right. The buggy is awesome, turns, jumps better than any of the other buggies I have driven.
FG101C
01.06.2009, 06:50 PM
Three more pics.
