Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
10.13.2008, 11:17 PM
The only time I've stripped the stock 14mm hexes is when they loosened a little. Replaced them and used lock-tite on the screw (especially the left side where the wheel spin direction helps to loosen them), and never had a problem thereafter.
Unsullied_Spy
Unsullied_Spy's Avatar
10.14.2008, 12:34 AM
Get some 17mm adapters for it and some JConcepts Rulux wheels. They look good, they're cheap, and they seem to be tough so far. Running them with Monster Truck Badlands on my Muggy and so far they work really well.
blueb8llz
10.14.2008, 11:43 PM
the people ive talked to that uses 17mm hex told me they get slop. not sure what theyre talking about, but i dont like any slop...especially if its gonna be around the wheels. but there was this guy that tried almost everybrand 17mm hex conversion, and he said the hpi was the best.
and i have yet to strip a 14mm hex either. i just check the nut after every run.
azjc
10.21.2008, 05:00 PM
there is no slop with the 17mm, 23mm is a different story though
VintageMA
VintageMA's Avatar
10.21.2008, 05:05 PM
+1 on the 17mm - I got both the OFNA and the Traxxas 17mm conversion for the Revo. I've been using the Traxxas 17mm hex and haven't had a single problem all summer.
“Everyone has a right to be stupid; some people just abuse the privilege.”
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.21.2008, 04:39 PM
They are as durable as they come.
Disadvantages
-initial cost
-heavier than non beadlock
-time consuming to install tires on
Advantages
-very durable
-ability to use the rims over when tires wear out
- AND THEY LOOK COOL AS HELL!!!
mkrusedc
NeuMaxx
mkrusedc's Avatar
10.21.2008, 04:43 PM
You sold me. Tower sent me a coupon for $5 off. Thanks!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.21.2008, 04:45 PM
While your ordering if you are converting to 17mm at the same time order yourself some extra 17mm nuts!
JaySki
JaySki's Avatar
10.21.2008, 07:20 PM
+1 on that.. and if you are running on concrete or ashpalt, just order another set of adapters as well. A nut WILL come off.. and that end up putting the treaded adapter spinning on the surface.. Bye Bye threads.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.21.2008, 05:02 PM
no more slop than stock at least!
mkrusedc
NeuMaxx
mkrusedc's Avatar
10.21.2008, 07:08 PM
Thanks. I do want the 17mm hex and would have forgotten...I must be getting old.
mkrusedc
NeuMaxx
mkrusedc's Avatar
10.21.2008, 09:20 PM
I hate Towers search engine. Either it sucks or I am a moron. Does anyone have a link to those adapters?
Edit: Mike's are out of stock: http://www.rc-monster.com/proddetail...Maximizer_2330
Edit again: I found them. I had to put the search terms in Google which hit on the correct Tower page:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXE06
e-rev project
10.21.2008, 11:51 PM
are the traxxas splined 17mm adapters better than the ofna 17mm adapters? i like the idea of the hex's locked to the shaft.
also what about the splines, do i have to get splined wheel to have any benefit in strength, or will it be a disadvantage if i dont.
thanks, i think im getting close
the tower search is horrible.
e-rev project
10.23.2008, 06:41 PM
ok i'm a little confused on the size of badlands i need
this is for a revo
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.23.2008, 06:51 PM
I'm using the Maximizer 17mm adapters same as Mike sells.
They are simple and light, with no slop.
As for the Badlands, I used the MT size and stretched them onto 1/2" offset LPR rims;
This makes the sidewall a bit more rigid. I did tape the insides of them before mounting to prevent ballooning tho. They are my best all-around bashing tire.
I am using the HPI Phaltlinges for street running;
I have the Crimefighters for the track (sorry no pic).
As for the badlands;
these tires;
http://www3.towerhobbies.com/cgi-bin...&I=LXNKS3&P=ML
I used these rims;
http://www3.towerhobbies.com/cgi-bin...?&I=LXTJB4&P=7
I was "supposto" use these;
http://www3.towerhobbies.com/cgi-bin...?&I=LXSBS0&P=7
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
