Soldermaster Extraordinaire
11.18.2008, 12:11 AM
Absolutely.
11.18.2008, 12:19 AM
Also keep in mind the pinion spins much more than the spur does. So even if the material on both was identical the pinion would wear faster. Say you run 13/46 gearing, the pinion rotates 3.5 times more than the spur. So hardened pinon needs to be many times harder than the spur to survive...
11.18.2008, 07:41 AM
very true linc, but that was after only 20 minutes of running
11.18.2008, 10:54 AM
I had a non hardened pinion with a plastic spur for a couple of months with very little wear. One night at racing my mesh slipped a bit and melted the spur. My only spare spur was a steel one, so I decided to use it for the last race which is only 5 minutes. After 4 minutes the pinion had no teeth left at all and my car had no drive.
RCM is smarter than me....
11.18.2008, 11:00 AM
Originally Posted by Patrick
After 4 minutes the pinion had no left teeth at all.
As opposed to right teeth?
The answer is no. And yes, mine is faster.
11.18.2008, 11:03 AM
 Gotta watch out for those left teeth!
RC-Monster Gold
11.18.2008, 11:29 AM
This is why balance is very important! This happened to me when I had my motor and battery both mounted on the left side.
11.18.2008, 11:54 AM
Originally Posted by Tempted
Don't know what your talking about, I don't see anything wrong with my post...
11.18.2008, 03:44 PM
LOL!! You shoulda left it alone! It was funny!
11.18.2008, 03:58 PM
Thats not right, should just left it alone
11.18.2008, 04:20 PM
Now I'm confused....
11.18.2008, 06:11 PM
Thats ok, probably happens to you often...right? You should be left alone to figure it out.
11.18.2008, 06:53 PM
If a tree falls in the middle of the woods and there is no one around to see it, which way did it fall, left or right
11.18.2008, 07:56 PM
Actually the humor is the fact that some people don't get the humor
11.18.2008, 07:58 PM
Who cares? It is a tree.
