ESC fire
transtalon
ESC fire - 01.02.2009, 10:19 AM
I had a similar problem with my old setup for my 5" extended Lst2. I wanted to make the Lst2 to go fast on the topend I geared it to high and the same
thing happen but with a lot cheaper components, KB45, Hydra 240 and watercooling setup. I put a +6 pinion on it with a 6S 8k lipo. I think you need to gear it down on your setup. How much does the FG weigh with everything on it? I learned that quick reaction saves other components from going.
mohanjude
Need for speed
mohanjude's Avatar
01.02.2009, 02:38 PM
I found that putting the BK controller back makes the motor behave as it should. However I dont want to risk another expensive controller catching fire. I have come to conclusion that the motor is not defective but something else in the setup may have been the limiting factor. It could have been a faulty controller or it could be that the truck that weighs nearly 20kg is too heavy. However anybody watching the truck would have been impressed with the torque / acceleration for the first 2 minutes..... Remember the pinion has nothing to do with the motor and Schulze controller - I have the motor on the bench and holding the shaft with my fingers. I can stop the shaft rotating with my fingers when the motor is coupled to the schulze at low rpm. On the BK controller I cannot stall it that easily. I coupled it to a watt meter and noted that stalling the rotor drew about 14 amps and low rpm but once the rotor stalled the schulze stopped drawing amps. What I dont know is if the BK controller overheats when the rotor is stalled. I cannot hold the rotor with my fingers to test it out.
Mohan
