mohanjude
Need for speed
mohanjude's Avatar
01.03.2009, 04:32 PM
That truck is quite something. Whats that yellow and black thing behind the red steering servo- rx pack?
Neil - yes indeed. Instead of using a BEC I decided to use a 5amp 6V receiver pack made up of NIMH. I am sure if I could get away with a BEC but at over 37V I didnt have many choices. I also orginally wanted to run the truck at 12S and I was having difficulties getting hold of a BEC to reduce the voltage that would not overheat when I was turning that massive Large scale servo (I tried a few Heli BEC's)
rabosi
01.03.2009, 09:04 PM
Wow!! That thing is gia-normous. Very nice man. That thread pattern probably doesn't help much at higher speeds either.
transtalon
01.05.2009, 07:13 PM
I think your tires are not for high speed blast like you intended to run. I t is the reason why it's bouncing like that, it probably balooning up like crazy when you hit the throttle. Very nice conversion, wish I have the money to make mine all nice like your conversion. Nice roll cage also. i also have 3X share of fire in my belt from ESC going from too much gearing for top end.
mohanjude
Need for speed
mohanjude's Avatar
01.06.2009, 03:25 AM
I used the Monster truck wheels for the traction. I first tried the stadium wheels and the torque was just wasted - you could see the wheels just spinning on the ground. The Monster truck wheels (Big foot) are much better at traction but dont do that well at high speed. I also think that the rubber is a bit old from sitting around and they have become kind of flat where they have been lying flat on the floor while the truck stood still. It may be worthwhile putting stiffer inserts or getting new wheels
It is icy cold - sub 0 temperatures here in the UK - I dont think I am going to go out for a spin int he next few days.
Ryu James
Ryu James's Avatar
01.12.2009, 02:02 PM
Mohan,
you are like the king of 1/5 around here. i love the truck. i cant wait to build a 1/5 in the future. i will be coming to you for help. btw, what do you plan to do with all those Neu motors you bought from me? any new projects?
Jammin SCRT10 Neu 1512 1y
mohanjude
Need for speed
mohanjude's Avatar
01.12.2009, 07:51 PM
Ryan,
I really love large scale brushless. I really want to build a fast but yet very torquey monster truck.
There is no supplier of Neu Motors that I am aware of in the UK. Whenever possible I stock up on the Neu's. I have got a Savage XL brushless with 3 speed and reverse. I know that the tranny is weak in this configuration but I dont want to bash this truck - just build a truck that hopefully have good acceleration but also have good speed due to the 3 speed tranny.
Eventually I would like to have 3 Large scale cars. A Monster truck, offroad 4 wheel drive from MCD and a street Racer / Stadium type truck.
Mohan
Nice rig.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Nice rig. - 01.12.2009, 08:16 PM
That is a nice rig you have there. The first thing you need to do is get that thing low to the ground if you want to go fast. You have a very sound looking chassis setup, and that cage is very nice also, but for high speeds you are much too high. Can you find some low profile road tires for that thing? There is no way you are going to go much more than 35 to 40 with those dozer tires on there. If you could hook up something like the Proline Roadrage tires on Axial beadlock rims, and get them balanced you might be able to get some really good speed runs out of that Bolido. how do you like the motor? I have a low and stretched out Maxx truck that I want to put a Bolido into for some high speed fun. Were there any heat issues running that setup? If not then you can always gear up for more, but your wheels are going to be a problem the way you have it now. Good luck.
Unsullied_Spy
Unsullied_Spy's Avatar
01.12.2009, 08:31 PM
The pinion that meshes up to the diff looks like it's ready to let go under that power, have you considered replacing it?
mohanjude
Need for speed
mohanjude's Avatar
01.12.2009, 08:35 PM
I originally had the Bolido on a 1:5 scale FG Race car setup.
Here is a simple video and pictures of it that I posted before
http://s476.photobucket.com/albums/r...t=fgstart2.flv
After I burnt up the tires just wheelspinning I changed the wheels to the much thicker Stadium wheels. More grip but the insane motor just wheel spun the tires. Once I mounted Bolido motor in the Monster truck the wheel spin issues went as the massive tires hugged the ground but now I am bouncing around at high speed. Got to get the balance right. Maybe if it stopped raining I could take the truck on gravel / field and try its off road capabilities. I tried hooking up to a Eagle tree logger but the amp draw at times is over 130 amps and the eagle tree is rated at 100amps. I have another more sophisticated eagle tree with the wireless dashboard - need to buy the hall effect amp sensors that use a coil through the power leads to measure amp draw as it is rated upto 200 amps
The motor runs cool it does not struggle hauling around a 25lb truck. You should have no problem in a stretched out Maxx truck.
mohanjude
Need for speed
mohanjude's Avatar
01.12.2009, 08:36 PM
Yes I have considered that - actually thinking of replacing the diff as well.
Thanks.
JERRY2KONE
JERRY2KONE's Avatar
Thanks. - 01.12.2009, 09:12 PM
Thanks for the input. It may be a few months before I can get it all setup, but I will post up when I do. I have four projects going at one time so my progress is slow. I just cannot focus on one project for too long, because I get burnt out. So I try to mixx it up and change projects from day to day. It keeps things interesting. I like your 1/5 scale project though. I hope to get into those next year for some fun. Keep up the good work and have fun.
