Shark413
Shark413's Avatar
01.06.2009, 05:28 PM
You mean something like this? The block on the motor mount has a 4mm screw that is used to hold the motor from moving away from the spur. It worked great, but once I moved up to a better motor (Neu which allowed me to tighten the motor mount screws tight enough to prevent the motor from moving( I no longer needed it. The Feigao's use softer aluminum and you couldn't really tighten the screws to much without fear of stripping them out.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
bruce750i
bruce750i's Avatar
01.07.2009, 12:12 PM
My 80mm Medusa was flopping around after a roll over the last time I had it out.
No stripped threads that I can tell?
Just hand threading the screw into the motor about three threads, I noticed that the screw would wobble a little in the the hole like it was too small of a screw?
My Medusa had a noob warning sticker on the box about using the right length and size screws. Something like no less than 3mm, no more than 5mm of screw into the motor.
pumpkinfish
01.07.2009, 01:58 PM
Bruce,
That is exactly how mine feels.
bruce750i
bruce750i's Avatar
01.07.2009, 03:38 PM
Mr. Pumpkinfish
I read the box sticker again to day at lunch, It said to use a 3mm screws and a minimum diameter of 2.MM?
I'm going to look for better fitting screws tonight.
With my 80mm, I feel there is a lot of weight hanging on the top screw working itself loose with every bump. And a 36mm dia motor compared to a 43mm dia, the motor weight has more leverage working against the threads IMO at least.
Bruce750i
Ps I was using mine in the E-revo
big greg
01.07.2009, 07:16 PM
if you go with a standard 6/32, you can shave the inside just a little and it will fit, i had to do this
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.07.2009, 09:25 PM
Seems like Mike should be making a motor adapter plate about now...
pumpkinfish
01.08.2009, 03:03 PM
I hope that is a thinly veiled hint
I have always thought that these motors should have some sort of support opposite the mount side. Even my Neu in my Kyosho 777 always had me worried. It never moved, but I alwyas check it. Is there any place I can buy one of those "ring clamps" and drill a hole in my chassis to mount it?
What's_nitro?
01.08.2009, 11:21 PM
The Neu motors have a much thicker front plate, something like 4-5mm. The Feigao motors do too. It seems like the Medusa motors are 3mm, or less, judging by the nature of the problem. My Lehner XLs also have a thin front plate, but they are smaller, lighter motors.
Those are 36mm motors, right? You can try these mounts. You would want the "05" size.
