Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
doo540
04.07.2009, 02:46 PM
Everthing is cool now, I installed the supplied 6mm diff shafts and then mounted the traxxas extended diff cups and everything looks to be fine. I need to add diff fuild and gearse to both the front and back and then tear up the lawn. Does anyone offer a aluminum diff cup for this diff? Doubt i will need it but you never know. If anyone is thinking of buying these V3 diffs, from everything I have seen so far, get them and get them quick. Should make the revo the machine it should have been from the factory.
doo540
04.10.2009, 01:00 PM
Does anyone have pics of the modifications they did to the frame of the e-revo to install the new V3 diffs? I can see I need to remove the rib that sits right above the diff housing. It also look slike I will need to make a hole thru the frame for the aluminum house to poke thru as it sits leave with the bulkheads.
