07.16.2009, 06:21 PM
Nice vid...especially like the end when the truck is sliding on it's roof for what seems like forever
Byte
07.17.2009, 07:14 AM
Thank you. My whole body looks like shit now because the car slided to oft on his back
PBO
RC-Unobtainium
PBO's Avatar
07.18.2009, 07:48 PM
My stock Rustler did it's highest speed (50.1 mph GPS) on it's roof!
Very nice vid
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
Byte
07.29.2009, 06:39 PM
Well, I just drove with my Rustler. Same setup as in the video. And now I know my Rhino can deliver 60C peak! This is incredible, isn't it? And what about the pack voltage? The minimum is 8.87, is this critical or is it good? And why doesn't my LiPo cutoff comes in? It's set to 3.0V so that would be 3 x 3.0 = 9V and the LiPo got under 9V?
Anyway:
skellyo
skellyo's Avatar
07.29.2009, 07:27 PM
Your packs are definitely not 60C, not even a 60C burst. If it were a 60C burst pack, your voltage would not drop below 3V/cell at that load level. 8.87 is definitely not healthy for that pack.
From what I see, you're pushing the very maximum limits of that pack and will be lucky if they last very long before puffing, especially when you start dipping below 3V/cell.
07.29.2009, 08:11 PM
I would need to see seperate volt,watts and amps graphs to give an accurate C rating judgement (the overlaid graphes obscure the voltage lines when its dipping low).
On the LVC issue, it seems it just isnt sensitive enough- I would raise ot to 3.2v per cell, maybe even 3.4v.
Byte
07.30.2009, 05:58 AM
I was just looking at the graph again. But the LiPo only got 2 times under 9 volt. And I was driving in grass hill up and down. Maybe because of going full throttle up hill got the LiPo beneed 3.0V/cell?
As you see it sometimes get over 80A and the voltage doesn't drop below 3.0V/cell
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
07.30.2009, 06:57 AM
i dunno!
i'd say it's doin a pretty darn good job!!
yeah so it's pushing the limits...but it weighs what? fark all and i bet it was super cheap too
looks like a heap of fun, the worse thing i did for my rustler is use the 3s 8000m,ah packs, too heavy but cant argue with 1 hour runtime under race conditions (that's how i got 2nd in the MT unlimited 1 hour mains , all the nitro's broke down/ran dry)
  Send a message via MSN to shaunjohnson
Byte
07.30.2009, 07:38 AM
Originally Posted by shaunjohnson View Post
i dunno!
What is bad/normal/good for a LiPo? A voltage drop under 3V/cell is bad? Exactly 3V/cell is normal and 3+V/cell is good?
It weights... well... yes, nothing It costed 15 dollar!
And yes it jumps like hell because it's awesome light! And I get a runtime of 15+ minutes. As you see in the graph I was at 13:30 minutes or something and I used 1050mAh of the capacity.
Wow, 1 hour... That's damn long, but I still like my 15+ minutes and super light car :) But for a 1 hour race that's perfect ofcourse!
skellyo
skellyo's Avatar
07.30.2009, 09:00 AM
Going under 3.0V/cell on a Lipo is not good at all. You'll shorten the life of the battery at a minimum. While you may be getting away with less battery, you're certainly not promoting a long lifespan of the battery running the way you are. IMO, it's just not safe to run a battery in application where it will be routinely subjected to currents beyond it's burst rating.
Also, IMO, if the Lipo was an optimum choice for the application, it should not drop consistently below 3.5V/cell until nearing the end of the run.
07.30.2009, 02:07 PM
~9.7v @ 80amps = 60c.. ermmm.
It is actually putting out 60c bursts- the voltage stays around 3.3v per cell, the current being drawn is up around 75-80amps, so 80amps / 1.35amps (1350mah pack remember) = 59.xxx. If you go by the heavier bursts, then its putting out around 40-50c bursts.
The weird thing is that some of the smaller bursts around 65amps are what cause the voltage to drop down to around 3v per cell. That I dont quite understand myself, could do with some more expert input & interpretation of the graphes.
It is still very impressive for such a small pack though, would love to see how a larger version of the same cell will perform.
skellyo
skellyo's Avatar
07.30.2009, 02:43 PM
I'm not sure where you see it staying at or above 9.9V at 70+A? It's routinely under 9.9V at most any current over 40A.
I'm not saying it's a crappy pack by any means. I just think it's way overtaxed in that application. Hitting peaks of 40C+ on every trigger pull is not a safe use of a Lipo, period. I stand by my comments that this pack is not being used safely and if it goes poof, it's absolutely the fault of the user for putting it in the wrong application.
07.30.2009, 02:53 PM
Its around the 375 second mark- but that is a fairly isolated incident. It does drop down around 9v with most 50amp bursts, but thats the thing- it isnt consistent. One 70amps burst drops it down to 9.7v, another a few minutes later drags it down much lower...
I would like to see a couple of these pacsk in parallel, that would boulster the performance for sure.
skellyo
skellyo's Avatar
07.30.2009, 03:44 PM
Oh, no doubt. I'd bet that if the capacity of this pack was doubled, the voltage would be maintained to 3.5V+/cell for just about any peaks.
RCShocker
RC Monster
07.30.2009, 04:50 PM
(It's a bit short, but it's a Trailer)
I say it's a TEASER .......
