Sylvester
Sylvester's Avatar
02.12.2006, 07:07 PM
The buggy is indeed fast!! I think its ok, if your motor is getting hot, does it have a heatsink, if it does, id go down a tooth or 2.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Superemaxx89
02.12.2006, 07:08 PM
hows the microcar 20120 controller compared to the warrior?
stampy
stampy's Avatar
02.12.2006, 07:17 PM
wow i though the savage was going to pull way more amps than the buggy but only pulled 5 amps more peak. that wattage on the buggy is crazy:004:
squeeforever
squeeforever's Avatar
02.12.2006, 08:01 PM
that might make it worse. brushless will get hot if over or undergeared. try one tooth higher if the esc and batteries arent hot.
Sylvester
Sylvester's Avatar
02.12.2006, 09:12 PM
Well he stated his motor was getting hot, not his controller/batteries, and i think this means its undergeared.
Losi 8ight e
Serum
Serum's Avatar
02.13.2006, 02:23 AM
Downloading as we speak..
Do you like your eagletree? since it's an inline, i personally do fancy the other one (eagletree system) what is your opinion on this recorder Viruss?
virusss
virusss's Avatar
02.13.2006, 03:49 AM
The savage pull only 5 more amp of the buggy because on 16 cell the 9xl not develops the max power of which he is able.In the buggy the controller and the batteries is warm, but the motor is hot, therefore i suppose is undergeared, my gear is 13/46...the microcar 20120 and the warrior is very similar(the microcar is little smooth).
Serum the eagletree power logger is very nice, is little offers many parameter to log,and work very well, for log, watt,amp,Rpm,voltage drop, for me is ok
Sylvester
Sylvester's Avatar
02.13.2006, 08:22 AM
Than it may be undergeared, how is your controller?
Losi 8ight e
virusss
virusss's Avatar
02.13.2006, 08:33 AM
in buggy warrior 9920, in the savage 20120 microcar
Serum
Serum's Avatar
02.13.2006, 01:06 PM
Encore...
Looking good Viruss..
1-0 for the buggy! wheelies..
virusss
virusss's Avatar
02.13.2006, 01:10 PM
thanks serum, what do you think about problem of temperature the 1940/8 in the buggy?the controller is warm but the motor hot, is undergeared or 6slipo is too much for that motor?
ah... for you which it is the average of amp draw what is looked at in the diagrams?
Serum
Serum's Avatar
02.13.2006, 01:22 PM
It are diffs that use 43/13 gears, right? what pinion/spur do you use? the motor makes about 44000 rpm on 6S lipo. That sounds a bit high.
What is the diameter of the wheels?
virusss
virusss's Avatar
02.13.2006, 01:27 PM
the gears is right, pinion 13 spur 46, the wheel diameter is 114 mm...
Serum
Serum's Avatar
02.13.2006, 01:53 PM
It is geared for about 75 km/h then..
How hot does it get? 50 degrees allready feels like burning the hand!
virusss
virusss's Avatar
02.13.2006, 01:59 PM
in effect i dont use a temp gun, in this week end I will measure, whit temp gun for a more precise temperature... i I have confronted whit a 9xl in the savage, this motor is cold respect a 1940/8...
you say what to me regard to the diagrams?
What is for you the average amp draw of two motors?
