Cartwheels
10.04.2009, 08:34 PM
Yes, the inner bearings are in there. I thought about shimming them but, I dont have the right shims and I could only get less than 1mm before I have trouble with the hub.
My diff measures 62mm from tip of the outdrive to the other tip of the outdrive.
Cartwheels
10.04.2009, 10:32 PM
Thanks guys for all the help!
The driveshafts are not all that easy to measure, but I keep coming up with 128mm pin tip to pin tip.
After carefull consideration, my A arms are the 1.0 arms.
I suppose I can limit droop. That helps a little.
