Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
DanteX
Talking 04.02.2010, 04:43 PM
*Update*
I received the outrunner today, and it is bigger than i thought.
But it fits pretty good actually.
I started to look for an aluminum motor mount and i finally cut an old rc chassis to fit.
I bent it and drilled the holes (there were holes before too )
And here are few pics:
Before:
Motor comparison: the can-motor used before and the outrunner
Then a picture after my work:
And some detail-shots:
The bending looks way more worse and it really is.
Thats all for now!
Regards, Andy
Manne
04.03.2010, 08:07 AM
Intresting project for sure:). Just a question, I thought the outrunner would be at least as long as the can motor? and doesn´t grass and stuff get stuck in/on the motor?
Keep up the good work!
DanteX
04.03.2010, 08:32 AM
Yes, indeed i have to think about an appropriate dust protection and cooling solution.
Why did you think so?
Q: Would it be enough if i cut a notch into the shaft of the motor instead of a end-to-end drill-hole?
Thanks
Regards, DanteX
Manne
04.03.2010, 08:46 AM
It just felt like with a directdrive system you would be in need of a HUGE amount of torque to get the rig moving without too much cogging, and i was thinking "longer motor, more torq" so I´ve got suprised when I saw how short it was
DanteX
04.03.2010, 10:17 AM
Next week i will see how it performs and then tell you if it worked :)
Happy Easter!
Manne
04.03.2010, 10:19 AM
Sounds good. Happy easter on you too
04.03.2010, 03:14 PM
If by notch you mean a flat spot to attach the drive cups, that'll work fine- maybe add a little dimple too for the setscrew to bite into.
DanteX
04.03.2010, 04:07 PM
Thanks, thats what i was talking of.
I will try it like you said!
DanteX
04.08.2010, 12:45 PM
WTF?!
Well, a few minutes ago i completed the reassembly of the savage and i did a test drive.
But this thing has no power. It can barely get speed.
If i let the wheels spin freely it balloons that much.
I think there was something wrong with the scriptasylum calculation.
I had to stop the test because the motor got almost too hot.
Any suggestions for improvement?
Semi Pro
Semi Pro's Avatar
04.08.2010, 07:33 PM
Originally Posted by DanteX View Post
*Update*
we put that exact same motor in an emaxx, just some advise, take it apart and reshrink the stator leads and then ca them down, or the motor will eat them for lunch
Last edited by Semi Pro; 04.08.2010 at 07:35 PM. Reason: removed some pics of the op to help with loading
Semi Pro
Semi Pro's Avatar
04.08.2010, 07:37 PM
its going to cogg
its not the length it the diameter that makes a big diffrence in torque with outrunners, to not cogg you would need an outrunnertwice that size
simplechamp
simplechamp's Avatar
04.08.2010, 08:14 PM
WTF?!
The values you used in the calculations are correct, but physics makes the calculated speed impossible with this setup.
Look at your rollout values, they are over 6:1. This means for every 1 turn of the motor the wheel will roll 6 inches, which is WAY too much. Should be closer to between 1:1 and 2:1.
With that high rollout you will have no torque at all, even with a low-kv torque heavy motor, because there just isn't enough gear reduction. That would explain why if you pick it up off the ground and let it freewheel in the air the tires might balloon huge, but once the motor is loaded up with the truck on the ground it can't get up to speed. It would also explain why the motor got so hot.
Semi Pro
Semi Pro's Avatar
04.08.2010, 09:20 PM
what kv motor did you get?
we were geared for 40mph and it spun the wheels all the way to 30 on 5cell..........just didnt last long
simplechamp
04.08.2010, 09:25 PM
Was the E-maxx direct drive though? You probably had a pinion/spur and transmission which all lowered the gearing.
Semi Pro
Semi Pro's Avatar
04.08.2010, 09:26 PM
no it was direct drive, let me see if i can find pictures for you
Tags
brushless, center, outrunner, savage, savage xl
