Gustav
Gustav's Avatar
04.03.2006, 12:50 PM
Originally Posted by nl12
Maybe you have a different kv motor than you think and it is hitting the 42000, maybe lehner mismarked the motor, stranger things have happened. Try the motor with a different controler like a 9920 unloaded and see if it does the same thing, if it does then something is definately wrong with the motor, if it works fine--maybe its your controler, maybe it is the mismarked kv issue. I dont know how to test the kv of a motor if anyone does that could help eliminate one potential problem.
Good idea about the mismarked motor but it can't be the 42K limit because it happens at 32.1mph(GPS) on 12.6:1 gearing which is less than 30K rpm i think.It will repeatably hit almost exactly that speed before it happens.
nl12
nl12's Avatar
04.03.2006, 01:03 PM
Another option is the MGM 16024 I am waiting on my 2240 to run it, but I will let everyone know how it works as soon as it runs. I am also using 8s lipo.
Gustav
Gustav's Avatar
04.03.2006, 01:08 PM
Yeah,please let us know how the MGM runs,the only thing that puts me off is the complicated programming,i hate reading instructions,the thing i like about the future -universals is the switches make programming so easy,adjusting timing,frequency,forward/rev etc is just a simple switch.
I have a 9920 so looks like i'll be running 20 gp2200s 'till i get this sorted (or a new controller:frown:)
nl12
nl12's Avatar
04.03.2006, 01:12 PM
'slow power' mode I would bet money that is your issue 5.5 inch diameter tires 20000 rpm and your gearing gives a little over 26 mph, your tires are probably bigger especially at speed. I bet the motor is stopping at 20K-24K RPM, repeatedly according to you I would find a local computer nerd and get that link program open and reprogram your controler.
coolhandcountry
coolhandcountry's Avatar
04.03.2006, 01:24 PM
do you have a programming cable gustav. You can look into it and see what is on.
Peace!
Country
Help support the
Rc-Monster
Buy here
Gustav
Gustav's Avatar
04.03.2006, 01:29 PM
Yes got the cable,just can't open the programm,get an error message in German.
coolhandcountry
04.03.2006, 01:35 PM
If you keep trying it and close everything that you don't need. It worked for me like that. I even get it some times when hooking it up. so have to plug and unplug a few times.
Peace!
Country
Help support the
Rc-Monster
Buy here
Dafni
Dafni's Avatar
04.04.2006, 12:48 AM
Weird. For me the programming software works flawless. Plug and play.
