Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Pdelcast
Pdelcast's Avatar
08.12.2010, 03:06 PM
Originally Posted by scarletboa View Post
wait; so this motor is LONGER than the standard flux motor? why is the kv higher?
Cheaper magnets... :) Kv goes up with lower power magnets.
Patrick del Castillo
President, Principle Engineer
nuz69
nuz69's Avatar
08.12.2010, 03:23 PM
The endbell screws are exactly the same as on the 1515 motor -- never seen one broken -- ever. Just we used them on both the front and back of the motor to lower costs (the front-endbell screws moutns on the 1515 are really expensive to machine -- lots of time on the CNCs)
It is the same screws of the REAR endbell I meant, the front endbell on the NEU-CC 1515/1y has stronger screws longitudinally mounted. I thought you change the system on the 1:10 scale motors for this reason, sorry.
I broke a motor front endbell with this system (ORION 2300Kv 4 poles), but the motor was hold by the front endbell, if in the HPI chassis the motor is mounted with front and rear fixation they should be no problem...
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Pdelcast
Pdelcast's Avatar
08.12.2010, 03:40 PM
Also, the front end-bell is glued in place, so there shouldn't be any issues.
Freezebyte
08.12.2010, 03:46 PM
Awesome, thanks Patrick!
nuz69
nuz69's Avatar
08.12.2010, 06:09 PM
I am very happy with Castle Stuff, but I had a bad experience with one of this lateral screw on my 1520/1Y :
brushlessboy16
brushlessboy16's Avatar
08.12.2010, 06:42 PM
looks like you over tightened it and had the screw head pop off. Could have been a defect in the screw
nuz69
nuz69's Avatar
08.12.2010, 06:51 PM
It happened when I tried to unscrew it, there is blue loctite in here I think, pretty tough to unscrew it. I will be annoyed when I will have to change the rear bearing next 2 or 3 year
Duster_360
08.12.2010, 08:28 PM
The ESC is a Mamba Max Pro, HPI special version.
What is it that limits the 2350 to just 4S then - MMP is 6S rated??
Pdelcast
Pdelcast's Avatar
08.12.2010, 10:20 PM
Rated to 4 cells in the Savage -- the 4 cell rating is specific to that application.
bruce750i
bruce750i's Avatar
08.13.2010, 10:47 AM
From the picture it looks like the Q-base esc has solder tabs on the power input.?
Pdelcast
Pdelcast's Avatar
08.13.2010, 11:49 AM
good point -- that is a difference. HPI wanted solder posts on the battery inputs.
08.13.2010, 01:42 PM
Cool, thanks for all the info Patrick, answers alot of questions guys were asking on a few forums that I've seen.
Semi Pro
Semi Pro's Avatar
08.13.2010, 02:00 PM
i have never broken one myself, they always strip before you can do that
Pdelcast
Pdelcast's Avatar
08.13.2010, 03:16 PM
Be aware -- those are TORX screws, not hex screws -- if you use a hex driver, you might strip them...
simplechamp
simplechamp's Avatar
08.13.2010, 03:49 PM
I really like that the Q-base has all solder post connections. I wish the MMP was available in this configuration. It's nice to have the motor solder posts on the MMP 1-cell, but then you give up the fan and internal BEC, and the battery wires are still soldered to the board.
Is there any way to buy the Q-base as a stand-alone item? Contact HPI? Or look at the RC "chop shops" on Ebay?
