Manne
09.12.2010, 05:47 PM
Just saw It, great job :)
Muggydude
09.12.2010, 06:32 PM
thanks. Tiem to go for my first big air bashing session. Will come back with results
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
Bmr4life
09.17.2010, 01:59 PM
DON'T DO IT!!! They aren't the same mah! The 5000mah will die before the 5200mah and you will go below 3V/cell on the 5000's before the 5200 hit the cut off, you risk destroying your lipos!
Just set the cut-off to a higher and safe number like 3.4v and it will be fine. That small 200mah difference isn't a big deal.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.17.2010, 11:02 PM
If you want to risk your lipos, esc, truck, and possibly life thats up to you.
Bmr4life
09.17.2010, 11:33 PM
Don't be so over-dramatic. Batteries in series see the same current. They will discharge at the same rate. If you run the batteries down to 0 mah left you were running them dangerously low to begin with.
09.18.2010, 08:05 AM
True and not true - You need to also consider voltage under load.
Batteries of different make, capacity, age etc will behave differently under load causing one battery to get significantly stressed.
Safety first - don't mix...
Manne
09.18.2010, 07:29 PM
Is the Truck airborn yet?
Muggydude
09.18.2010, 07:59 PM
Mine? Yes. Spent all last weekend backflipping it off a skate ramp. Broke a few turnbuckles!
1/16 BL E-revo
Manne
09.19.2010, 03:52 PM
Sounds good! Might wanna try these:
http://www3.towerhobbies.com/cgi-bin...?&I=LXWSY0&P=7
But probably you already know about them :)
Bmr4life
09.19.2010, 05:26 PM
You can get them for $28 shipped on ebay.
Muggydude
09.19.2010, 08:42 PM
Which I did! Can't wait to get them...
1/16 BL E-revo
Bmr4life
09.19.2010, 08:44 PM
Nice. Mine made a huge difference. My rear rod ends were worn so bad the rear tires would point outward ever time I hit the gas. That problem is completely gone now.
