Serum
Serum's Avatar
11.24.2006, 02:20 PM
It's not about the quality of the controller, it's the quality (or lack) of service...
coolhandcountry
coolhandcountry's Avatar
11.24.2006, 05:05 PM
That is nice. I like it.
Peace!
Country
Help support the
Rc-Monster
Buy here
marc993turbo
11.24.2006, 07:50 PM
Originally Posted by VWT4
Yes, I have 4 Hyperion 3.700mA VX, two 2S and two 3S.
I bought the motor mount and a beautiful transmision case already polished, but the case don't fits in the Lightning chassis :007:
Hallo!
Why doesn´t the case fit in the lightning chassis?
I have the same transmission case and want to install it the next days into my lightning chassis... where´s the problem?
The case is the exact dimension the original emaxx case has...
Marc.
VWT4
11.25.2006, 04:10 AM
Originally Posted by Serum
Is that the horror controller you are using?
Serum , when I wrote the post I already knew you love Schulze stuff LOL
Marc, mine is only a little wider than the space between the lower braces:
--stock case is 44,45mm
--aluminium case is 44,50mm
If the FLM case fits I will sell the GPM and get the correct one.
Vicente.
Serum
Serum's Avatar
11.25.2006, 04:15 AM
that .05mm can't hurt that bad..
You can use a gasket between the two halves, i know Ryan used it for his.
VWT4
11.25.2006, 04:29 AM
I don't understand you.
Adding a gasket between the halves won't change the width of the case, only the length will increase.
BTW .05mm metal to metal conntact didn't let me fit the case.
Serum
Serum's Avatar
11.25.2006, 04:35 AM
So if you drilled out the holes of the chassis with .1 it would be ready to go. not too hard imo.
marc993turbo
11.25.2006, 05:45 AM
Hi !
I know what you mean, i tried to install the gear box this night and no, it does not fit.
I am going to buy a milling cutter for my dremel today and cut out the
missing 0,5mm from the braces.
That will not hurt the stability...
Marc.
marc993turbo
11.25.2006, 05:49 AM
Hi !
I think you are refering to the transmission half cases that don´t fit quite well because they are too short.
You can either use a gasket or dremel a little bit on the input shaft...
I did the second.
Marc.
coolhandcountry
11.25.2006, 03:01 PM
Hi !
Marc.
I think I would use a file first. The dremel is good for larger amounts.
The file is a safer more even cut.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
11.25.2006, 03:07 PM
Since it's only .05 mm, a drill which is .1 larger in diameter should solve the problem without leaving any traces.
coolhandcountry
11.25.2006, 04:19 PM
Is it the inside of the stuff or the hole?
Peace!
Country
Help support the
Rc-Monster
Buy here
crazyjr
crazyjr's Avatar
11.25.2006, 04:36 PM
The way i read it, was that the trans. case was too wide not a hole alignment problem
Serum
Serum's Avatar
11.25.2006, 05:23 PM
my reader must be down at this moment..
VWT4
12.10.2006, 05:25 PM
Here is a short video.
The SuperBigMaxx doing backflips .... you can do all those that you want, one after another one. Absolutely no cogging.
I really love my 18.149 + Big Pletty combo :004:
