03.05.2007, 12:36 AM
All I know is that both my son's Stampede, which included a Futaba radio, and the Photon (I think it uses a Futaba-based radio although it doesn't say it) both needed to be reversed.
strodedawg
03.07.2007, 08:21 AM
hello,
i have tried to do what everyone has recommended with no results. my digital camera is down so i will describe my set-up.
- double battery positive wires soldered to a deans plug's positive
- double battery negative wires soldered to another deans plug's negative
- double wire bridge from the positive of one plug to the negative of the other
- all shrink wrapped
- using 2 x 7.4v 8000mah lipos
double motor wires:
- 5.5 plugs - one lead soldered into the plug
- second wire soldered to outside of the plug and shrink wrapped
- connected to motor
- UBEC positive soldered to positive lead and negative solderd to the negative lead
- both bridges removed
futaba 2pl radio with throttle channel reverse - i beleive the controller can't find neutral on the radio and cannot get it to recognize either the motor or radio. endpoints are at 100% and trim is at 0. tried an associated xp radio system with no results - will be trying a jr system tonight or tomorrow.
really confused - i everything seems to be solid and done correctly.
thank you for all the help
jim
let's build something sick!
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.07.2007, 10:36 AM
Originally Posted by strodedawg
if by jumper you mean the red and black wire form the receiver plug then yes.
There should not be any plugs removed from the controller's receiver leads. If these are removed, reinstall and try again. To program - both the black and red jumpers should be removed. Upon completion of programming(before unplugging the batteries), the red jumper gets reinstalled. Unless I am misreading this, it seems like you pulled a couple leads from the controllers rx lead, which may be the trouble(and would explain why you have the same problem with any radio you try).
Serum
Serum's Avatar
03.07.2007, 10:48 AM
Yes, if this is the case, the controller doesn't know it has a signal.
strodedawg
03.07.2007, 11:10 AM
the leads are all in the receiver plug. i pulled the jumpers out of the esc under the shrink wrap. i can't even get the darn thing to beep at all.
thanks
jim
Serum
Serum's Avatar
03.07.2007, 11:12 AM
All you can do now is try another receiver/transmitter and please let us know how it goes.
strodedawg
03.07.2007, 11:21 AM
thanks will be trying it tonight
RC-Monster Mike
Site Owner
03.08.2007, 09:51 AM
It may sound stupid(and I know you aren't a rookie), but make sure the rx lead is properly oriented in the receiver(though with Futaba style plugs you really can't screw it up, the warrior has a generic style "fit anywhere" plug). You may have to try the reversing of the throttle channel as well.
strodedawg
03.08.2007, 10:59 AM
on the receiver plug for the controller, which color is positive, which is negative and which is signal? i just want to check as my friend is bringing over his m8 and jr radios to test.
jim
nieles
nieles's Avatar
03.08.2007, 11:05 AM
brown = -
red = +
orange= signal
  Send a message via MSN to nieles
strodedawg
03.10.2007, 10:22 AM
last night used a jr synthesized radio and a m8 and the damn thing wouldn't program. just used the ubec and the mamba maxx controller i had for a gt2 conversion i started. i tried to hook up the mamba maxx 5700 motor to the esc, resoldered all the connections and tried with every radio i could find and not response. what should i do with this expensive and useless piece of electronics smash it? send it back and wait forever to get it back?
any comments would be appreciated.
thanks to all that have given me help
nieles
nieles's Avatar
03.10.2007, 11:01 AM
can you post a photo of the wires?
maybe there is something wrong, but probably not.
Romster
03.10.2007, 11:44 AM
Strodedaug,
Don't SMASH IT!!!!!!!!!!!!!!!!!!!!!
Just wondering is the BK 12020 esc bought new or used?
Can you try to get some pics.
I just want to see your set up so I could see the problem.
strodedawg
03.10.2007, 07:41 PM
yes the controller is new, i will take pics on sunday after racing.
thanks again
Serum
Serum's Avatar
03.11.2007, 03:06 AM
that's more than odd; two controllers in a row that don't programm on your gear. Can you please follow Nieles' advice on the pics?
