glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.30.2007, 08:50 PM
Unless I missed it... nothing was said about the voltage cutoff. Double check that cause it won't run if that's not set right. (disabled is best for that setup)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
t-maxxracer32
t-maxxracer32's Avatar
03.30.2007, 09:06 PM
http://video.google.com/videoplay?do...95581892052880 heres one of the videos..
03.30.2007, 09:29 PM
Good point GD, I didn't even think of that. I just saw the way he had it wired and what he said the mode was and figured that was it.
If the spur turns as well as the input shaft, I would suspect that the problem is somewhere inside the tranny. Do you still have the shift fork and gear changing dog gear installed? If so, the shift fork may be in the middle of first and second gears. If using a single speed conversion, how are you locking the tranny in second gear? Are you using the steel idler?
t-maxxracer32
03.30.2007, 09:31 PM
http://video.google.com/videoplay?do...68046314316357
another one
t-maxxracer32
03.30.2007, 09:32 PM
sheesh brian... lol dont knwo all of that stuff... im not even sure what gear it is in... and that pitch fork... how do i tell about all those things?
maybe ill get some pics of the tranny taken apart... lol
03.30.2007, 09:57 PM
LOL. OK, look at the pic below.
The hole is where the shift fork would go. It slides in for second gear, out for first gear, and in the middle for neutral. If it is not held in one position, it can move around taking it in and out of gear.
Mike.L
Mike.L's Avatar
03.30.2007, 10:35 PM
what position was it in, did you have anything to ceep it locked in?
  Send a message via MSN to Mike.L
t-maxxracer32
03.31.2007, 12:03 AM
o its just sitting there lol what do i have to do to it?
t-maxxracer32
03.31.2007, 12:04 AM
o i stick it in??? will do tha not and see what happens!
Patrick
Patrick's Avatar
03.31.2007, 01:51 AM
It looks like you have nothing holding the shift linkage in place like the other guys said, so it's just falling in and out of gear.
If you push it in that will be 2nd gear, and if you pull it out that will be 1st gear.
Obviously if you want to be able to shift gears while driving you'll need another servo.
t-maxxracer32
03.31.2007, 02:05 AM
lol no thanks you!! so if i lock it in first will that mean i have more acceleration but less top speed? right now it is locked in second
thanks
Patrick
Patrick's Avatar
03.31.2007, 02:10 AM
Yes, 1st gear for acceleration, 2nd gear for top speed.
Second gear should have good enough acceleration though, depending on pinion/spur combo, and assuming thoose motors have at least as much torque as the titans.
Most people only use second gear.
