supralover72
supralover72's Avatar
04.27.2007, 09:28 AM
YEY! IT came yesterday!
But I had MJOR diff problems. It took me 2 and a half hours to fix it and Turns out I broke a diff cup. I put a center diff outdrive in each front and rear and f/r outdrives in the center and realized AFTER they were assembled. grrrrrrrrr.....:mad:
My complaints so far are the instructions and the some of the tediousness of the steps.
The instructions make NO note of specific things like left and right and aren't very specific, which I expected a little, but not this much.
The parts aren't marked left and right and the arms are right f/r on one instead of left/right on one parts tree.
The fronts hubs aren't marked left/ right.
Other than that, OMG! I see now why people pay this kind of money for buggies.....GORGEOUS!
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
04.27.2007, 09:50 AM
should of gotten an xray, no problem assembling those.:D
losi 8ight-t
xray xt8
AAngel
04.27.2007, 10:13 AM
Ahhh, XRay, the love of my life.
So, where's the pics of the CR? If you haven't done it already, you might want to go ahead and order some extra suspension arms. From what I've seen, the CR(T)s handle very well, but wear a bit faster than others around the pins. Maybe it's the plastic they use. When they get to a point where you notice the handling degrading, you'll want to change them.
supralover72
04.27.2007, 11:44 PM
^Thanks, but looking for parts, figuring out which bag they're in, and time has made me only able to assemble the front suspentions and steering assembly so far. I'm getting there though. So far I only have pics of hte box, contents, and my favorite pic, everything laid out ;).
I didn't want the X-Ray ONLY BECAUSE: I got a pro level national chapion for the same price and already have a spur that's able to fit.
Plus, the breakage was my fault, so whatever.
Aragon
04.28.2007, 06:27 AM
I'm busy with a CR conversion as well. I didn't have problems with the assembly per se, but I had and still have problems with the design of the rear antisquat setup. The FTE kit ships with a 3 degree alloy antisquat rear arm hinge plate, but it doesn't align with the front hinge plate! Whoever designed this kit took a shortcut and didn't design front hinge plates to match the antisquat angle set by the rear hinge plate. To get the rear arm hinge bolts in you either have hammer them in, or you need to switch to the plastic antisquat plates that are able to flex. Luckily the kit includes both the alloy upgrade and 3 standard plastic antisquat plates, but talk about bad design.
My other gripe with this kit is that some of the brand new ball links have slop straight after installing them... WTF.
I think I'll go Mugen next time.
supralover72
04.28.2007, 01:34 PM
^That's interesting, I didn't have the ball cup problem. But GEEZ! CAN THEY MATCH BAGS TO STEPS! OMG!
But wow, everything is a work of art on this buggy. The braces are like air.....yey! ;).
EDIT: Well, it's almost 100% but I still have to fix the center diff and get some extra screws for the chassis braces as I was shorted :(.
