Originally Posted by BrianG
The first pic would cause problems. The "ground" point from the BEC feeding the LVC is floating at 1/2 total battery voltage. Since the LVC sees the whole pack voltage, it might totally short out "battery 2", unless the balancer inputs were isolated somehow from the rest of the LVC circuit.
The second pic looks like it would overcome this issue since all ground references are at an equal level.
Sorry all for beeing such a noob at this, BrianG are you refering to the pics in MetalMan's post #15 or mine (with your pics) #9 ?
What pic in what post would work with the Hv-Maxx ?
If possible I would like to keep the Hv-Maxx connections intact and use the internal BEC, otherwise I will just monitor the BEC side as a 2S pack.
Monitoring all cells would be better since I might not always charge both packs to its full capacity and if I then mixup BEC side and non BEC side I might go lower then whats recomended on the non BEC side since that wouldnt be monitored.
