Originally Posted by MacII
My E-CRT has been through three revisions. I'll save you the long story and say this:
1.) NO WAY to make it work without a motor mount like Mikes (something with the motor and diff on the same metal!) I had a 2 pc and it was a nightmare.
2.) Hot Bodies Ring & Pinion help with gearing. Currently I've got the HB R&P on the Diffs and the Kyosho 46T Spur mating up with a 10T Centrury Pinion all running on 4s...I'm currently using one of those mystery XLT-1 Motors which I think is somewhere around a 6XL or 7XL.
3.) I've had the batteries in both the one large block and the side by side setups. I prefer the side by side...the truck feels more balanced.
Here is a photo of my current E-CRT...
Mac thank's for your repliy, your battery layout is what i was looking for. I plan on ordering mikes truggy mount, because im going to use the stock spur & start with a 16t pinion. Acordding to brians calucator that should get me around 32mph.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 62
Pinion Tooth Count: 16
Total Voltage: 14.8
Motor KV: 1853
Tire Diameter (inches): 5.5
Tire Ballooning (inches): 0
Motor Current Draw: 60
Motor coil Ω: 0.0092
Spur/Pinion Ratio: 3.88 : 1
Total Ratio: 12.81731 : 1
Tire Circumference (inches): 17.28 inches (438.88mm)
Total Motor Speed: 26401.54 RPM
Vehicle Speed: 33.7 MPH (54.14km/h)
Effective Speed Rate: 2.28mph/V (3.66kmh/V)
Effective KV Value: 1783.89
__________________
