06.27.2007, 11:13 PM
If using a saw, you have to use a serrated blade at low speed if you don't want to melt the plastic. Also, take small "bites" and back off to let the plastic cool. You could also try a miterbox, but the score and snap method seems to work the best for me and doesn't require a lot of work - just a sharp knife...
rchippie
rchippie's Avatar
06.28.2007, 12:19 AM
Originally Posted by rustnpede
What are some diferent ways to cut Lexan without using special tools?
Im making the esc and battery trays for my revo, using 3/16" lexan, a sharp knife and the score/snap method. Ive made 3 cuts that took more effort than I thought would it would take. Ive seen lexan knives in the hardware store. would they make the task any easier?
For that thickness i use my table or ban saw, with a blade made for cutting plastic. A router works very well also.
REAL MEN RUN BRUSHLESS
AAngel
06.28.2007, 12:39 AM
I try to stay away from power tools when cutting plastic. I think it's more of a PITA than it's worth. If you don't want to use the score a snap method, try a hacksaw with a fine blade.
rchippie
rchippie's Avatar
06.28.2007, 12:48 AM
If you use the right cutting tool it's acctually eaiser. A coping saw with a fine blade maybe better than a hack saw. The blade is very felxible & cuts turns very eaisly.
redhatman
Nitro PWNS > Electric??? Really? Wanna race?
redhatman's Avatar
06.28.2007, 12:50 AM
It's all opinion, lets not start a flamewar now.
BL Lipo RC18 - Mamba 6800, Apogee 3s
BL Revo Project - MM, 8XL, 12 cells to start
E-Maxx - 650's, EVX, 12 cells
  Send a message via Yahoo to redhatman Send a message via AIM to redhatman Send a message via MSN to redhatman
rchippie
rchippie's Avatar
06.28.2007, 12:51 AM
I'm not flaming at all just stating my opinion . for me presonally it's eaiser.
AAngel
06.28.2007, 01:03 AM
To each his own. Plastic is relatively soft. It heats up quickly and melts and the possibility of making a mistake is greater.
Believe me, if i can turn it on a lathe, mill it, grind it, or cut it with a power tool, I'm there. Hand tools just work better for me when working with lexan.
rustnpede
RC-Monster Parking Attendant
rustnpede's Avatar
06.28.2007, 01:27 AM
Looks good redhatman:cool: . I also bought 2 sets of the associated battery cups,but realized that they will not fit the lipo I plan to use:rolleyes: .
I scored the otherside of the piece and they snapped very easily. Some of the score lines did not match up so im probably gonna round all of them off after all.
Is the lexan we are using to fab out chassis components similar to lexan used for r/c bodys? Im thinking of painting the underside of my esc mount and battery trays. Will polycarb paint work on the thick lexan sheets.
redhatman
redhatman's Avatar
06.28.2007, 01:30 AM
yes, thick lexan = thin lexan = polycarbonate...lol.
The special RC paint is meant for lots and lots of flexing so it doesnt chip. You may even be able to get away with regular paint, as long as it isnt going to flex much.
rustnpede
rustnpede's Avatar
06.28.2007, 01:38 AM
Yeah I figured as much. I was worried if any certian type of paint will cause the lexan to "fog".
