Thread Tools Rating: Thread Rating: 19 votes, 4.37 average. Display Modes
09.09.2007, 07:29 PM
Tis none too shabby. One thing I will suggest is make sure screws holding the drive cups on the tranny & diffs are threadlocked to heck, or better still use the stock traxxas screw/pin thingy- I find it a bit more solid in that it locks the cups to the output shafts. You will also need lots of threadloc on those too.
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.09.2007, 09:24 PM
Thanks for the comments. I already have them threadlocked. I lost a few before w/ Titans and 14 cells
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.09.2007, 09:28 PM
I'm glad you're happy with the poles dude... :)
if you really like the power poles.. you can get the 45 Amp bars from robotmarketplace.com.. that's where I get a lot of my stuff..
robot combat uses the really "BIG" pole connectors... :)
this would be worth the upgrade.. Just tryin' to help you out dude.
http://www.robotmarketplace.com/mark...onnectors.html
45 Amp PowerPole Extra Contacts
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.09.2007, 11:04 PM
Have you thought about the FlexTek suspension? From a strengh-to-weight standpoint you can't get much better than titanium! They shouldn't weigh much more (if any more) than the RPM arms.
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.09.2007, 11:12 PM
Sounds like just what I would want. Got a link?
Never mind. I got it. What about a titanum chassis? Does anyone make one?
Edit: Ouch almost $300 bucks. I just spent almost that much on an MGM controller. I think an extened chassis and stronger diffs first. Thanks for the advice. Maybe I can talk my wife into them for my bithday in February.
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.10.2007, 02:52 PM
Thanks. I'll check when I get home.
VintageMA
VintageMA's Avatar
09.10.2007, 10:49 PM
Sorry, my bad - I didn't remember the setting right off the top of my head.
'Forward to Brak to Reverse' is the one that will slam into reverse on you.
The softer handling one with the reverse delay is 'Proportional w/ Reverse Lockout'. This is the one with the 2 second delay return to neutral before allowing reverse setting. This is the better setting to use if you want reverse. You only reverse when bashing to get out of a pickle and with this setting you will not get reverse unless you really want it.
“Everyone has a right to be stupid; some people just abuse the privilege.”
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.11.2007, 04:05 PM
Thanks that is the one I was using, Forward to brake to reverse. Even at 20% of brake it was still flipping. I'll try the proportional w/ reverse lockout tonight.
VintageMA
VintageMA's Avatar
09.11.2007, 04:10 PM
That'll probably fix your problem. You might want to bump the brakes up to 50% until you find the right setting when you make the change - just so you actually have some brakes.
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.12.2007, 05:32 PM
Hopefully GOOD BYE and GOOD RIDDANCE to MM cogging. I just got my TMM 16018 in the mail. Beefy compared to the MM. I can't wait to install...........
lxmuff
lxmuff's Avatar
09.13.2007, 08:44 PM
What's the latest?
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.15.2007, 09:28 PM
Here it is. I just finished the install. Now to program it.........
jnev
jnev's Avatar
09.15.2007, 10:25 PM
Looks good. Let us know the programming is? Hope it runs well fro you.
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.17.2007, 01:25 AM
I'll tweak the programming tomorrow and check temps. So far the inital test runs were very smooth with zero cogging.
mkrusedc
NeuMaxx
mkrusedc's Avatar
Talking 09.22.2007, 04:00 PM
I finally got a chance to run my NeuMaxx. Bashed for about 35 minutes on the New Orleans levee. 20 minutes into it the tires were still balooning. . It ran very smooth without any cogging.
Temps were:
90F ambient
117.6F esc
128.2F motor
The only damage was 3 lost body clips and a mounting screw for one of my shocks stripped out of the arm hole.
I'll try to post another threads with my first attempt at vids.
Tags
e-maxx, flm, mgm, neu, ulimited engineering
