sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
11.02.2007, 11:07 PM
This link will explain alot about diff fluids and diffs.... enjoy
http://www.rc-monster.com/forum/showthread.php?t=5050
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
Matthew_Armeni
Matthew_Armeni's Avatar
11.03.2007, 12:18 AM
Wow, it was awesome, until I stripped a spur doing a wall ride . I have the 3.3 chassis I got from Arct1k but no brace, and I had the slipper set maybe a little too tight to bash with (I race with it tight). My mesh may have been just a tad tight too, maybe. Also, it didn't switch gears, I think it was stuck in second. Well I'm going to replace that spur and I got a body to paint, but I'll post some pics first. My Mamba and TrueRC battery were both cool to touch but the fiego was getting hot already (only ran for about 5 min neighbor saw me do a wallride perfect then said I should do it some more, another neighbor comes out.... you get the idea). The clutch felt really good, smooth starts. Theres a little more deadband at the beginning of the throttle as opposed to a direct drive setup but I think it feels good. Something I was thinking about the clutch, it should lower the peak amp draw because it is easier to get the car moving. Anyway, any questions?
  Send a message via AIM to Matthew_Armeni
Matthew_Armeni
11.03.2007, 12:37 AM
Some stuff I got
The TeknoRC kit as it come out of the box
Battery Tray
Bottom part of motor mount
Mount standoffs
Matthew_Armeni
11.03.2007, 12:46 AM
ESC plate
Tranny mount for plate
The elec clutch, you don't have to use an e-clip, a 3mm screw and washer work too
The motor mount, the slot is so you can get to the setscrew
And something cool about the motor mount (If I mounted mine in the low position the motor would have just barely rubbed the rear arm, but that's because I am using the RC-Monster heatsink, the higher position fits fine, and it you run a neu there's no interference, I can't give up the extra cooling for lower cg)
And because I live in San Diego, where Tekno is based, regular mail only takes a day to deliever
Matthew_Armeni
11.03.2007, 12:57 AM
And finally, a complete shot, after my spur gear incident
11.03.2007, 02:05 AM
So... How is it? Does it run well, any quirks?
Matthew_Armeni
11.03.2007, 02:50 AM
Yeah ,it runs really well, great actually. The quirks I had were my fault, I was in a rush to assemble it and did not properly shim the clutch, it's fine now, and the slipper was a little tight, fixed that as well. Painting the body now, everything will be ready to race for tomorrow
riceman
RC-Monster Gold
riceman's Avatar
11.03.2007, 01:05 PM
Looks great Matt - You racing Barona today? I was going to try to make it out today for the kick off of their Saturday points series. Too many new projects popping up due to the wind/firestorm. Hope to race with you soon.
t-maxxracer32
t-maxxracer32's Avatar
11.03.2007, 03:06 PM
that looks great.
whatd the teckno kit cost?
drkros3
11.03.2007, 05:36 PM
tekno revo conversion
its only 150 for the kit. not bad.
wheeldean
wheeldean's Avatar
11.03.2007, 07:17 PM
It was $129 if you preorderd it but now its full price since they started shipping this week
t-maxxracer32
11.03.2007, 07:21 PM
mmm i guess thats not too horrible.
saves you time from trying to figure out where to mount stuff.
Matthew_Armeni
11.04.2007, 02:13 PM
Well I won my main in MT, lapped the other guys too. Hopefully there will be more racers next time, I like a bigger field, it's a lot more fun. I temped my clutchbell, motor, ESC, and battery after each practice, qualfier, and main. 5 min quals, and 1 10 min main(after the main I did a bunch of donuts too). My highest temps of the day were
-Clutch-116
-Motor-166
-ESC-118
-Battery-121
Outside temps-the high was mid 70's but in the sun it felt like mid 80's.
I was running the RCM xl heatsink on the motor and a novak 25mm fan on the MM. Also, I started the day running 15/38 stuck in second because I stripped my 36 spur the previous night and 18/36 is just barely too tight to run (17/36 should be fine, as well as 18/34-haven't verified this though) but I wasn't fast enough on the straight and did not have enough pickup to clear all the doubles. I was able to get a 36 spur at the track so I threw that on and also went back to the 18 clutch for the second qualifier, bingo! I was now clearing all the jumps with ease and zooming down the straight. Also of note is that my temps stayed pretty consistent with the gearing change. In fact, the only change in temps (more the 10 degrees) was the battery after the main (due to the longer run time). The battery was around 101-110 during the 5 min quals.
I think I covered everything, so here's a few pics, also, a link to the tracks site.
drkros3
11.04.2007, 10:03 PM
hey just wondering how are the run times on it. thats the same set up im going to be running soon.
Matthew_Armeni
11.04.2007, 10:58 PM
I should be able to get 15 min racing. We did a 10 min race, I ran 2 warmup laps (my average times were around 38 to 40 sec I think), a victory lap, and some donuts. I'll have to time it next time I run, I'll do a bash maybe tomorrow.
