DrKnow65
DrKnow65's Avatar
01.03.2008, 01:11 AM
sounds like the throttle is over traveling for the ESC.
Should have bought the Mamba Max ;) You can still save up for the MMM if you get this to work for now
Just ribbing yah :)
ib4200
nota newb
ib4200's Avatar
01.03.2008, 04:35 PM
well i plan on buying either the new novak or the mmm eventually...
  Send a message via AIM to ib4200
01.03.2008, 05:19 PM
I would suggest ressetting the esc and radio- cutting out at full throttle sounds like the EPA is too high ( the novak esc doesnt like 140%- turn it back down to 100% if you have that function). Also make sure the radio trimm is set to neutral before reprogramming the esc. If that fails to solve te problem, then the esc is most likely toasted saddly. Were you using the 4.5 motor with the esc that died?
ib4200
nota newb
ib4200's Avatar
01.03.2008, 08:04 PM
well i tried everything suggested and it still didnt work i was running the original hv maxx motor which was the 4400 correct me if im wrong(before the 6.5 and the 4.5)
01.04.2008, 08:03 AM
Yep, the original motor was the hv4400. Well, that sucks alot- it seems you are out of options really, one way or another the esc will need to go in for repair/replacement.
ib4200
nota newb
ib4200's Avatar
01.04.2008, 04:33 PM
im just gonna wait for the new systems...
