skellyo
skellyo's Avatar
01.31.2008, 08:38 AM
Originally Posted by cart213 View Post
According to Brian's speed calculator, 65+ mph should be possible with 2 MM5700's. Also, tire ballooning will increase his top speed, so I don't think you should try to minimize it.
Gearing up is a much better option for hitting top speed than to desire tire ballooning IMO. Trying to keep a truck tracking straight with pizza cutter tires is no easy task for the driver or their steering servo having to fight such a large inertia.
rootar
rootar's Avatar
01.31.2008, 08:47 AM
i would definatley go with dual mambas and dual 7,8,or 9Ls for motor the L motors would tolerate being geared up alot better than the little mamba motors. Run one of those on 3s and gear it to the moon with light as possible tires.
jzemaxx
01.31.2008, 01:05 PM
On 3S which would be the most powerful then with twin setup?? The mamba's or the 7, 8 or 9L's. How about the XL's or Neus's??? Money is no concern...I just want to be able to place near the top...lol.
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.31.2008, 11:57 AM
The mamba's are no good for such a big vehicle. You need as a minimum L-can motors. Go for the Foam tires. Imex has them. Pizza cutters are very difficult to control and are very dangerous. A 10Lbs vehicle going 60+ mph will cause serious injuries and damage, when control is lost.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
squeeforever
squeeforever's Avatar
01.31.2008, 06:31 PM
I would have to disagree. Two Mamba's in a MT will be more than enough.
I would go for either two MM5700 or 6900 setups using Komodo LP tires. There lightweight and won't balloon. If moneys no object though, maybe go with two Neu 1509's with a couple MGM 9012's.
rootar
rootar's Avatar
01.31.2008, 12:20 PM
i think it said he had to run offroad tread tires = no foams or slicks
jzemaxx
01.31.2008, 01:07 PM
Correct, that is just the rules.....
I am going to run some Imex tires with beadlock wheels to keep them on the rim. Also I haven't been able to find a stiff enough foam. They are 6.7" diameter tires.
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.31.2008, 12:58 PM
That's just dumb and dangerous if the rules state to only run offroad tires in a speeding Monster Truck. But if that's the case, just belt the tires with tape and stuff it with the stiffest foam available. Ballooning tires are cool when bashing, but in a real high speed race (even in a controlled enviroment), is just asking for trouble.
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.31.2008, 01:13 PM
It wouldn't be such a bad idea to use a really thin film of RTV on the beads of the tires when using beadlocks. Let is dry overnight or longer before use. It will have a stronger hold that way. I can rip the tires of my beadlocks with one pull of the trigger.
jzemaxx
01.31.2008, 01:24 PM
Yeah I will try that, but I really need stiffer foams for these things. That will help also....but have had a heck of a time finding them.
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.31.2008, 01:29 PM
If there is a Joan's fabric store(or such) around you, they have some really stiff/firm foams available which you can cut up as foam inserts. I have used some of their foams when I had built my own couch for the house. Good stuff.
jzemaxx
01.31.2008, 01:33 PM
Hmm I'll try that.
About the setup for the 3S's how do the setups I posted about stack up??
Would I be better off with twin mamba's or the 7, 8 or 9L's. How about the 7, 8 or 9XL's???
01.31.2008, 01:38 PM
XLs will have lower RPMs and require even more gearing - with two motors I think the 7L 3500kv would be a good bet...
01.31.2008, 01:39 PM
Or how about dual Novak HV 4.5s...
jzemaxx
01.31.2008, 01:50 PM
Looking at the 3500KV's they seem to be the same as my current Velineons which are 3500's which are on my 3905 truck. My 3906 truck with the two 7L's , would it really be anymore powerful then the two Velineons on 3S's?? How would 6L's do they are 4096KV's and seem to have a little more grunt then the 7L's?? The RPM's though are a little over what the motors are rated though...
