Takedown
WARNING: May become violent.
Takedown's Avatar
02.02.2008, 11:49 AM
Ok Im gonna leave the decision up to PB.
Takedown
Takedown's Avatar
02.02.2008, 12:46 PM
Hmmm... You think a 50-55 would work?
Takedown
Takedown's Avatar
02.02.2008, 01:13 PM
Also which 50-55 outrunner would you reccomend?
Pedebeater
Pedebeater's Avatar
02.03.2008, 04:33 PM
I will be using 4s, no question about it. They are maxamps 5000HV packs. I was also thinking that a bigger motor would do a little better, but i also thought the kv was perfect. I got a friend at my lhs that has an algorithm that will tell me about the speed I will be looking at. All I got to know is the tire diameter, diff ratio, and motor kv (still to be determined). If you guys have any suggestions on motors please share, if possible try to find one on www.hobbycity.com. The prices are amazing.
Thank you for all of the help.
Faster than a cheetah on cocaine
  Send a message via AIM to Pedebeater
Takedown
Takedown's Avatar
02.03.2008, 06:54 PM
I personally think the 50-55 600kv would be perfect. I just tried it in my bros e-maxx and it was amazing! The tires were about to blow. I would not go for anything over 600kv because that alone is to much power.
02.03.2008, 07:08 PM
Plus the lower kv should help with startup and overall amp draw. BL-Power seems to be having good success with a turnigy outrunner, but he is using 8s lipo, which cuts the draw in half compared to your 4s setup. You batts should be capable of 90amps or so.
Let us know the tire diameter, diff ratio. That with the battery info should allow me to make a decent choice of motor. What esc wil you be using, a mamba max?
zamis85
zamis85's Avatar
02.03.2008, 07:27 PM
+1 on this one
Pedebeater
Pedebeater's Avatar
02.03.2008, 08:22 PM
Diff ratio: 2.923
Tire diameter: 5.311in Balooning rate of tire: about 1.5in
Battery: 4s lipo. 20C Constant(100 amps) 30C Sustained(150 amps) 50C Burst(250 amps)
esc: mamba max
If you need any more information please ask.
02.03.2008, 08:30 PM
Ok, I am going to say that an out runner between 500 and 550 kv will be where you want to be. 50-55 size looks good, but the 600kv may be too much. For the price you can give it a try.
83gt
02.03.2008, 08:37 PM
make sure and take a video of the e-savage shattering all the bevel gears, outdrives, and half shafts. ;).
J.
Pedebeater
Pedebeater's Avatar
02.03.2008, 09:06 PM
I will be using cvd's at the arms, probably revo centers and I will be using these scpecial yokes for the motor.
http://www.rc-monster.com/proddetail...mrevov2coupler
Thanks again for all of the help and please keep the suggestions coming.
83gt
02.04.2008, 08:05 AM
Nice. what plans do you have to fit CVD's ? I havn't found a solution for that yet. Those Yokes I think are set up for 8mm outdrives. I don't think you'll find a way to fit 8mm bevels into the e-savage diff case.
J.
Pedebeater
Pedebeater's Avatar
02.04.2008, 05:25 PM
No, those yokes are for the motor, the motor shaft is 8mm. I will be using the generis EXarms with cvd's once the deal goes down.
Pedebeater
Pedebeater's Avatar
02.04.2008, 06:27 PM
I just found this. It is shorter but wider. The stator dimensions are all larger. It has a 6mm shaft instead of a 8mm. It also has 20 more kv, will that make a serious difference?
New one
http://www.hobbycity.com/hobbycity/s...idProduct=5388
Other
http://www.hobbycity.com/hobbycity/s...idProduct=4907
Thanks again for all of the help.
sikeston34m
sikeston34m's Avatar
02.04.2008, 07:12 PM
New one
Other
20kv will not make a noticeable different.
IMO, either one of those motors has potential. Either one will work.
At this point, I would base my decision on which size shaft will make for the easiest hookup.
IF your truck's stock transmission shaft is 6mm in diameter, then I would go with that one.
Then I would get a stock transmission shaft that is the length you need. The Original E maxx tranny output shaft is 65mm in length and 6mm in diameter. The stock Revo output shaft is 85mm in length. Each one has a steel "hump" in it, but that's easy to turn down. Stick it in a drill. While spinning it, use a grinder or a file on it. Go slow when you get it close so you don't remove too much material. Final polishing can be done with sandpaper.
