Serum
Serum's Avatar
08.27.2008, 01:27 PM
I tried quite some different methods, ductape is ususally the best. Make sure the tires are clean (on the part you apply the tape to)
tried all sorts of glue, but i had a hard time vulcanizing the rubber of the tires i tested it with (mulchers)
Ductape, two layers should do the trick..
http://rc.stuurmijmail.nl/Balloon%20...ent/index.html
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.22.2008, 12:43 AM
Excellent thread guys thanks for all the info!
09.22.2008, 12:59 AM
Very welcome, I had always wondered how to do the taping and balancing and can recommend the process. I will do it to everything I own!
Gee
A Horse's Ass
Gee's Avatar
09.22.2008, 01:57 AM
I took a couple of old arms and removed the shaft from the axle to use for a balancer. Some of us aren't as lucky as linc to have a prop balancer just laying around. Had a couple that were so out of balance I was about ready to give them away. Tried the golf tape and balanced them and they work great now. The epoxy putty is a good idea too.
09.22.2008, 02:04 AM
I like the clamp and table idea. My prop balancer is just big enough to do a std maxx tire. I was going to need something like this to do my lst tires...
I like the epoxy putty but wish it was a bit heavier. My buddy gave me some sticky lead weights that are used to balance full size tires. I may try to cut them up a bit and use them!
