George16
Supermaxx
George16's Avatar
09.07.2008, 10:03 AM
That's why I run my 3 nitros to ease my frustration and withdrawal . Long live my nitros .
Luciano, can you get that 10S ESC delivered any faster ?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
lutach
lutach's Avatar
09.07.2008, 10:10 AM
I was told the ESCs will be shipping out on Monday. If there's any delays I'll let you all know, but I hope they can ship it out. So tonight we will find out.
emaxxnitro
emaxxnitro's Avatar
09.07.2008, 10:34 AM
my mmm died on 4s, did not try 6s
09.07.2008, 04:07 PM
Originally Posted by mohanjude View Post
I am not going to wade into this ongoing arguement to flame Castle as I like their products. I have had many Mamba 25 units for the 1/18 scales, mamba max for the 1/10 scale. Using my past experience I ordered x3 Mamba Monster Max and they are sitting brand new in the box unopened - Why? Because I am scared to 'break' them.
I have never purchased a piece of RC equipment and worried about it failing prematurely. If I use the same logic on all my RC gear I should worry about Receivers dying, Gyros failing in $4K Turbine helicopters, speed controllers failing in the large electric models traveling at 70 mph. I have over a dozen of of the ESC's from MGM, BK, schulze and Quark - they too have failed 'occasionally' I am not scared of using them or even abusing them. I am too scared to get the MMM out of the box!!! Maybe if I disable the BEC, use 2S lipo and use a 24 turn motor and run the truck at 5mph I might be OK.
The problem here is that Castle released the V1 and found out it had issues. fair enough that can happen to any company. Then after a considerable delay they released V2 - in the four weeks it has been out it has received a lot of negative presss. Please don't forget this is exactly how the problems with V1 happened. So for those people who want to either live in hope or denial keep this in mind that things may not be all ok. Who knows - time will tell. When you walk into a shop and purchase a Ipod, mobile phone or whatever electronic device for your PC (graphic cards/ processors/,memory) you are not immediately thinking of sending it back after 'playing' with it for 15-30 mins. Lets face it a ESC only works for 20-30 mins contiously at a time - that is minuscule compared to the hours we have all the toys working in our daily lives.
Having to return stuff for repair and wait for weeks is not what the hobby is about. It is about enjoying and relaxing - about creating and innovating. Having to worry about the stress of premature failure, return for repair and worrying if the repaired unit will fail is in my book something I can do without. There are plenty of other things one can do with several hundred dollars invested in the hobby for each truck that can be spent with less stress. Next time you buy that 42 inch plasma screen think about how long you expect it to work out of the box. So I think it is only fair that people from both sides of the arguement see each others view.
Well put. I will say that if you have 3 MMMs then one will most likely be fine. You may have to kill the other 2 to find it though!!!
I have 3 of them, a V1 that is going strong, and 2 V2s. The 2nd V2 seems to be doing fine. My 1st V2 did die after a decent sized jump... And my V1 has some high density foam installed for "pcb suspension"!
I have so many r/cs that it really does not matter if I break most of them. I find wrenching just as relaxing as bashing. I will say that my aftershock is not taking the abuse very well. Time to upgrade to lst2 spec arms and hubs. Pity, as the truck is only 45mins old, and I am already upgrading it....
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.07.2008, 08:24 PM
Linc get rpm arms. The lst2 arms break just as easy, well almost. The other lst2 parts should be ok but they still break.
And as far as the MMM is concerned "Blow'em up and send them back" is my motto. If everyone leaves them sitting in the box castle will never know they have an issue still. I'm in Australia too so shipping is costing me but even with all the shipping costs the car is costing me less then it would if it was running.
09.07.2008, 08:27 PM
I ripped apart a rear toe link, so the lst2 setup looks alot better. I will most likely get the rpm arms after I break some of the stock arms. Looks like I can get a great deal on all of the parts necessary to do the swap. I have not damaged an arm yet, but it is just a matter of time...
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.07.2008, 08:33 PM
My friend was running the LST2 front and rear ends but kept breaking A arms, front toe links and front knuckles. He went rpm a arms and 8t toe links or muggy ones (can't remember exactly but they are off another losi) but he is still breaking the knuckles all the time.
e-mikey
09.07.2008, 10:35 PM
The pimp should have his speed controller in check like his hoe's. You need to get your pimp hand stronger kid.
09.07.2008, 10:46 PM
I will have to check out the muggy links (friend has one) and see if they are beefier. The Lst ones look pretty wimpy, and the ball ends break (plastic tears around the ball). Anyone make good al knuckles? Is there a good brand of al hopups? Not interested in the arms or bulks, but the knuckles look like a good thing to have in 7075 or something like that...
Kid? I am only a year younger than you old man...
I may have to take you to the "Gun Show" as you obviously have no idea whats going on
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.08.2008, 12:43 AM
I just asked him what knuckles he wants and they are the new era ones. I asked why and he said because they are the best. I still don't know why but it's worth looking at.
On the turnbuckles here is the info http://hdrcvideos.com/forums/viewtopic.php?f=18&t=10884
09.08.2008, 12:50 AM
Thanks for the info, I may have to check on the lstforum and see what the guys over there think...
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.08.2008, 01:02 AM
Thats where he gets his info and I added to the post above about the turnbuckles (lst forums).
coolrunnings
09.08.2008, 02:12 AM
Truckbasher, they do make a real 1/8 scale esc its called an mgm 160.24...just because it's to expensive doesnt mean it aint real. Call mike and ask him what he thinks of the 160.24 he has been brutalizing one in a 12 pound savage on 6s and it never flinches. Just because castle dont have a reliable 6s car and truck control doesnt mean one doesnt exist.
George16
Supermaxx
George16's Avatar
09.08.2008, 02:31 AM
Yes, but the MGM 160.24 is out of stock .
How's the 160.18 compared to the 160.24?
Revo with OS .18TZ
TruckBasher
TruckBasher's Avatar
09.08.2008, 05:31 AM
My bad I forgot about that...though I hear a few of them also got up in smoke.well I am on the process of ordering the 16025-3 Z series to try for my self... I think they changed the models.
ohhh i never said anything about the price
E-Slayer direct drive to diff
