speedracer1129
12.08.2008, 11:59 AM
Here is a thread you might to check out if you really want to know what you are getting into: http://www.hpibajaforum.com/forum/sh...ad.php?t=13998
lutach
lutach's Avatar
12.08.2008, 12:13 PM
I agree. Better to do it right the first time than to do it twice.
A smaller motor can push it, but as others say, it will get too hot too fast. For something that large, you need torque - and that requires a large motor. I too would look at the 1527 at a minimum, but the 2215 probably would be more optimum.
Once you get your motor choice squared away, use high voltage to keep current levels manageable. Even on 10s, I would expect large current spikes on startup simply because of the size/weight. For something like this, I would like a 200A ESC @ 10s (or 12s), otherwise the ESC will be working hard IMO. I don't think the Sentilon will like this setup unless you can have someone parallel 2 or 3 of the FET boards, but then you are at ~$300. At that point, might as well get an MGM or something. Contact Castle - they might have a recommendation for you (they have a large HV/200A ESC in their special projects page). They may be able to custom build you a super-HV110 by adding one or two more FET PCBs, but that will cost more.
No matter what, pushing a 25lb vehicle to 40mph speeds is not gonna be cheap.
He could use a Jeti SPIN200? I do have 3 of them .
