George16
Supermaxx
George16's Avatar
01.21.2009, 08:58 PM
The front uses the same length dogbone for the e/t maxxes; 57.5mm. There's a bit of play so you'll need to put one o-ring for each cup. 59mm would be the ideal length if you decide to have one made by RCalloy.
I can't see the picture from work.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Rivermaxx
01.21.2009, 11:00 PM
Cool!! I have a few extra front stock length ti shafts.
Besides
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Besides - 01.21.2009, 11:29 PM
Besides the O-rings you can also use some silicon fuel tubing to buffer the gap in each drive cup. It really does the trick and since you are still a nitro guy I am sure that you have some laying around. Good to see that you are having fun figuring this build out for BL. Have a good one.
