$w!ft
01.31.2006, 02:12 PM
16 cells in series, with a y-adapter in series, 1930/12 motor, 1/8 ue diffs, 17/72 gearing. 3rd cycle of batts which are 1 year old (ballistic batteries zapped and assembled) and have never been run, NOT fast enough :P
Maybe its my wheels spinning inside the tires. Ill give it 4-5 more cycles with the fixed tires then i decide on a 1950 or a 22 series if the mounting is not too difficult.
OH and does the 22 series work with 18120?
Cheers!
coolhandcountry
coolhandcountry's Avatar
01.31.2006, 02:45 PM
Could you get a video of your truck? I liketo see what it is doing. It should be fairly quick. Unless you want a all out speed demon.
Peace!
Country
Help support the
Rc-Monster
Buy here
$w!ft
01.31.2006, 03:28 PM
I can do that. Where can i host my vid.
E-maxx-kid
01.31.2006, 03:43 PM
www.rcpics.net
boss 302
01.31.2006, 04:51 PM
I kind of disagree. that would be like saying you don't need a 2240 unless you have a 15 lb truck. It is the user goals that determine this. I like more power. as long as the drive line can almost survive.
i figured you would dissagree and i also understand why you like power.
remember i said you dont really need a motor bigger than a 1940 unless your truck is over 12 pounds but i didnt say you cant put a bigger motor in your truck. I also thought he might be on a tighter budget(like me) than somebody else.
i would actually like to put a 2240 in my truck but i cant afford one right know
dont get me wrong i have always thought the more power the better and i will always think that way
coolhandcountry
01.31.2006, 05:21 PM
I can not speak about a 2240. I have the 2250 and it is awesome. I have not got the full potential yet. I am trying some things to fix it. I want to try a 1950 as well. I have a 1930 10t now. I think it is a nice little more. It is pretty decent on speed and power.
Peace!
Country
Help support the
Rc-Monster
Buy here
coolhandcountry
01.31.2006, 05:26 PM
Hey swift. Iwas crunching some numbers on your truck. You are under geared with that truck. It should be running about 22 mph top speed. That may be a problem on wheelies to. Do you have some other gearing to try. Go back to a 66 tooth spur and 18 pinion. I may be off on tires size.
May even want to try a bigger pinion than that. Something about a 20 or so.
Peace!
Country
Help support the
Rc-Monster
Buy here
$w!ft
01.31.2006, 05:58 PM
I read somewhere that a guy called Emaxxman AZ runs the same gearing and he had very similar motor to me so that is why i chose this gearing. But the thing is the car is not even pulling wheelies with this gearing. Are you sure about the gearing? I have a 66 tooth from my original E that i can try.
Here is the car i was talking about:
http://forum.maxxtraxxusa.com/showth...2&page=1&pp=10
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.31.2006, 06:17 PM
I can get any Lehner motor you want, but I have a feeling coolhand is probably right. The 1930 motor is a little powerhouse and judging by your posts, you have something going on with your setup. I would be happy to sell you another motor, but lets get to the bottom of this first - another motor with the same incorrect battery configuration(or whatever the issue may be) will still be unimpressive. I have a 1930 is my G2R and it has pLENTY of power. Got any pictures of your wiring?
$w!ft
01.31.2006, 06:55 PM
6volt rx pack plugged into Receiver, 16 cells, y adapter, deans, 12 gauge wire, BEC pulled out...
RC-Monster Mike
Site Owner
01.31.2006, 07:07 PM
Wiring appears to be in order. Gluing the tires will be a huge impact, along with a gearing change(just caught this). You are barely geared for 20 mph! Get your hands on a Traxxas 54 tooth spur and a 22 tooth pinion and you will get a respectable speed(mid 30s). With a 22/66, you are just about going to get 30mph. I can certainly see why you are unimpressed!
Nick
COOKIES!
Nick's Avatar
01.31.2006, 07:09 PM
I'm suprised at how long the wires are, maybe cut them down abit. Shorter wires give less resistance. I doubt thats your problem though.
~ Nick.
boss 302
01.31.2006, 07:10 PM
gearing is definately your problem and the wires shouldnt make that much of a difference
coolhandcountry
01.31.2006, 07:53 PM
Well swift this is from my experence. A 9xl on 14 cells and 14 72 gearing won't hardly left the front tires. I put the a 18 51 gearing on 14 cells and it will do back flip almost. I don't know why it is like that.
You may want to look at a strobe slipper. It is much better than the stock setup or robinson. Which in turn put you closer in the gear range the motor wants.
Peace!
Country
Help support the
Rc-Monster
Buy here
MetalMan
MetalMan's Avatar
01.31.2006, 10:42 PM
If you are undergeared and not getting wheelies, that's because the motor isn't pulling enough amps. If you gear up, the motor pulls more amps, thus creating more torque.
