virusss
virusss's Avatar
01.29.2006, 01:10 PM
ok perfect thanks,fact this as I make knowing if the just relationship is? As an example my result is of 97 KMH is too much?
Serum
Serum's Avatar
01.29.2006, 01:12 PM
yeah, that is rather fast.
1940/8 on 6S right? with a 51/12?
Serum
Serum's Avatar
01.29.2006, 01:14 PM
And what is the outer diameter of the tires?
virusss
virusss's Avatar
01.29.2006, 01:16 PM
The motor is 1940/8 6S lipo, tire is 114mm pinio 16 spur 44, for this motor 6S is correct o too much?
Thanks
boss 302
01.29.2006, 02:02 PM
Originally Posted by Serum
(Dafni is currently building a setup like that too, only with a 1950)
only dafnis is going to be in a revo i think
Dafni
Dafni's Avatar
01.29.2006, 02:38 PM
Serum is right. I have a Mugen MBX5 here, and I tested many setups on it.
I feel lipos make it almost "too light", so I compensated with a big motor :027:
But the Revo is correct, too. I'm still waiting on shafts to complete it, though.
Rene, you can use 36cm for buggy wheel circumfence, btw.
virusss
virusss's Avatar
01.29.2006, 02:43 PM
Dafni,for you what is the speed correct for a buggy in KMH?(Gearing pinion spur)
And the 1940/8 whit 6S is OK?
Dafni
Dafni's Avatar
01.29.2006, 02:52 PM
On 6S, you should be able to gear for 40mph without problems. For constant running, I gear my buggy for 35-40mph (app.60kmh, maybe) But for speed runs, I think I squeezed way more out of it :017:
On the buggy I like "slower" motors and more voltage. 6S is plenty!! 5S works fine for me, too. (correct motor assumed!) Already 14Ni cells are enough for a 1/8 bug.
How many rpm/V has the 1940/8??
virusss
virusss's Avatar
01.29.2006, 03:09 PM
1960rpm volt but I do not know if the lehner they are load or unload
Serum
Serum's Avatar
01.29.2006, 03:20 PM
1960kv
Serum
Serum's Avatar
Which is under load viruss. all the motor's of BK are rated under load.
virusss
virusss's Avatar
01.29.2006, 03:24 PM
My motor is a lehner no BK
Dafni
Dafni's Avatar
01.29.2006, 03:29 PM
1960rpm/V on 6S might be a bit too much! Especially for a buggy. You will not find a small enough pinion. 5S would be better, or even 4S.
Serum
Serum's Avatar
01.29.2006, 03:38 PM
LOL! BK is Lehner!
:p
virusss
virusss's Avatar
01.29.2006, 03:40 PM
Ops.. :)
