Sylvester
Sylvester's Avatar
02.15.2006, 05:30 PM
mmdooley, very nice truck, but do you really think its safe to run without bumpers?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
mmdooley
mmdooley's Avatar
02.15.2006, 05:38 PM
I have not finished it yet. But I do have the FLM skids on the front and back will that not give me some protection??
Sylvester
Sylvester's Avatar
02.15.2006, 05:50 PM
well if you hit it hard enough, it will just bend and could damage a part.
Losi 8ight e
mmdooley
mmdooley's Avatar
02.15.2006, 06:03 PM
What would be good bumpers for this setup??
squeeforever
squeeforever's Avatar
02.15.2006, 06:09 PM
stock. also, if it runs backwards the best thing to do is flip the diffs or reverse the tranny driection. most brushed motors wont like to run in reverse all the time.
mmdooley
mmdooley's Avatar
02.15.2006, 06:17 PM
It's the evx that's backward because the wheels roll forward at a slow speed. And when you push the throttle to reverse it will roll the wheels in reverse at very high speed. But I got it better than that. Right now the wheels roll forward at high speed but I am pushing the throttle in reverse.
02.15.2006, 07:44 PM
Why is that squee? The only thing I can think of is if the brushes have been "broken in" in one direction.
mmdooley
mmdooley's Avatar
02.15.2006, 11:58 PM
Yall are losing me, I have the hybrids and as long as they are running in the same direction they are right,right???
Sneeck
RC-Monster Custom
Sneeck's Avatar
02.16.2006, 01:50 AM
The only thing that will limit the speed of the titans is the evx. It run's faster in forward than reverse, so flipping the diff's is a bad idea.(you are right that brushed motor's do run slower in reverse due to the brake in, but the evx is slower) Flipping the tranny would be a 3rd option, but the real problem is the radio setting's. Reverse channel 2 and adjust the trim, then re-set the evx. It should hold the setting's, if not there is something wrong.
Dafni
Dafni's Avatar
02.16.2006, 03:02 AM
Nice truck there! What servo will you use to turn those wheels??
The 8XL is a good choice, btw!
I hope you get it going soon.
Another thought: If you look at the brushes of the Titans, you can see why they have a prefered running direction.
mmdooley
mmdooley's Avatar
02.16.2006, 03:20 AM
Thanks I will check the titan's, I have a JR650M and it's working great (on the table) As soon as I get the throttle to work right I will tell you how it does on the ground. That's one reason why I wanted to run the titan's first, to see if the heavier chassis would need more steering servo. I also wanted to check drivetrain and wheel alignment etc... I think it will save parts and labor if I tweak the e-maxx before going bl Know what I mean. :027:
coolhandcountry
coolhandcountry's Avatar
02.16.2006, 09:09 AM
I wouldn't worry about trying to get the titans going right since you are going brushless. Unless you planning on running the titans for a good little spurt. That is just my opinion. If you get the titans to go in the right direction that is what matters. If you have to reverse the wires on the motors instead. The titans don't have timing so that is a plus.
Peace!
Country
Help support the
Rc-Monster
Buy here
