TexasSP
Something, anything, nothing
TexasSP's Avatar
08.28.2009, 04:08 PM
Takedown, get on the RX7 forum and research. Ask questions, take your time. You can get way more out of that rotary naturally apsirated than 160 hp. I have a friend that was putting over 300 to the ground NA back 10 years ago. In a car that light with a motor that light you are talking some serious power. The torque of the small block conversions cause many issues.
I can tell you the sound out of that 300 hp rotary was a trip, and to see this guy take out vettes and the like was plain hilarious.
www.cubicle101.com
Takedown
WARNING: May become violent.
Takedown's Avatar
08.28.2009, 05:22 PM
Ive been lookin around on rx7club for the past few months now and have learned alot but try to avoid posting because I sound like a total newb when it comes to rotary engines. Argg. Ill see what I can find.
RIP- Tammy (9/14/08)
Foxracin
08.28.2009, 07:17 PM
You cant get any help or knowledge without asking. Got to start somewhere.
Takedown
Takedown's Avatar
08.28.2009, 11:54 PM
True
Takedown
Takedown's Avatar
08.28.2009, 11:56 PM
Well bad news... Was gonna go cruise around in the rx7 this morning but it wouldn't start. It turns over fine but won't fire. I've never had this happen before. Tommoro I'm going to go over the probable causes such as the ignition, fuel pump, fuel filter etc... Hope I can figure this out.
big greg
08.28.2009, 11:58 PM
did you turn the key? lol sorry i had to
Takedown
Takedown's Avatar
08.29.2009, 12:10 AM
Of course I did. Haha...
big greg
08.29.2009, 12:16 AM
it was turning over but no spark huh? could you hear the fuel pump kick on?
Takedown
Takedown's Avatar
08.29.2009, 02:11 AM
didn't check anything yet. Will get to all of that tommoro.
Foxracin
08.29.2009, 09:36 AM
Check for spark first. Then fuel.
Takedown
Takedown's Avatar
08.29.2009, 12:26 PM
I just hope it doesnt have to do with the ignition.
TexasSP
TexasSP's Avatar
08.29.2009, 01:00 PM
You may have flooded it and slightly fouled the plugs with oil. This happened to me on mine every now and then. Wait a while and try again. When mine would start back up it would smoke heavily through the exhaust burning off the oil for a minute or so. Rotaries work more like a two stroke and burn some oil anyway.
Worst scenario you may have fouled the plugs, but those are cheap.
www.cubicle101.com
Takedown
Takedown's Avatar
08.29.2009, 02:25 PM
Ok well i just took out the fuel pump and tested it. It was good. tested the connections to the fuel pump, there good. and lastly i checked for sparking. "no spark". This is the beging of finding my way out of a maze. Possible issues, bad coils, bad wires, bad sparks, bad connection to coils... etc. The spark plugs were replaced with iridium plugs last month and I dont think all of the spark plug wires could have gone bad. beging to think its the coils.
TexasSP
TexasSP's Avatar
08.29.2009, 05:47 PM
Just remember one plug can foul the whole deal. I had a bad trailing plug in my 89 GTU that gave me all sorts of hell. The big issue was the fact whoever had put it in cross threaded it and we could not get it out. The issue with the rotary being you cannot use a heliocoil(sp?) to re-thread a stripped plug hole. Unfortunately I was broke at the time and did not know rotaries that well and sold it for $750.00. OUCH! This was 1999 and the car was in good shape otherwise. It was a loaded GTU and I loved it!
www.cubicle101.com
Foxracin
08.29.2009, 07:01 PM
Stick a screwdriver in the end of the spark plug wire and hold it away from a ground somewhere and see if it sparks that way. If its spark there you know the coils and wires are good so the plugs would be the problem.
If know spark there pull the wire off the coils and spin it over. The coil should ark to the negative terminal, or a ground somewhere on the coil so that way you can rule out the coils. You can also touch it and see it is shocks you. lol doesnt hurt that bad but you can definitely feel it. I wouldnt recommend this method though. Ive done it a few times though.
If nothing from the coils it could be the coils, pick up, wiring, Lots of things.
