I have to get me some mounts made to fit the gmaxx mount. I going to test one out and then a dual system out. I want to compare and see how one does. Then I can see how much a two motor setup is different. Not only that but I am also building a truck for this project run. :027:
Cool, Sounds like fun! hope it all turns out well.
Based on some calculations in a spread sheet I have the 380XL 8Turn motor is approximately the same as a 540s 12 turn motor. Also, you can look at the Kv and Amp draw of the two and see that.
Kt calculated to be 0.459869101 for the 380 8XL
Kt calculated to be 0.451318458 for the 540 12S
But, the IO is higher on the 380XL than the 540s so that hinders the torque output of the 380 a little bit. The 12t 540S turns out to have a very slightly higher torque output than the 8t 380xl, but not by much.
