nastety92
09.10.2013, 09:55 AM
Originally Posted by PBO View Post
It would be moderately terrifying trying to pull that thing up with front discs the size of washers & rear drums. Totally understand why you'd want to actually stop using the C6 option
Yes the stock brakes were pretty Terrifying. Trying to stop the truck after a 1/4 mile run at the strip especially with low tire pressure made for an interesting experience. I'm really looking forward to driving the truck with these brakes. We are actually going to be running a dual rear caliper setup. One set of calipers will be used just for racing to lock the rear wheels.
Nick
Tamiya TRF801Xt-e
PBO
RC-Unobtainium
PBO's Avatar
09.10.2013, 04:45 PM
How would that work? sounds interesting but I don't understand
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
nastety92
09.11.2013, 08:50 AM
There will be a toggle switch inside the truck and that will get turned on so it will lock the rear caliper, then once I go to launch the truck it will release freeing the rear wheels. It's not setup yet, but hopefully it will be soon and I'll have more info.
Nick
Tamiya TRF801Xt-e
nativepaul
nativepaul's Avatar
09.11.2013, 01:35 PM
How would that be useful? Sounds interesting but I don't understand.
When you first mentioned it I was thinking of a drifter, wanting a rear only brake to initiate slides, adding a second calliper could potentially be easier than converting the existing handbrake/Ebrake to hydraulic on some vehicles. But for the drag strip I'm baffled, is it FWD? It could be for burnouts, but I thought trucks were all 4WD or RWD and I don't see the benefit in just burning out the front tyres on a 4WD.
Unless you have a front only brake too and burn out the fronts and rears separately which would be safer than doing all 4 together.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
