captain harlock
RC-Monster Captain
captain harlock's Avatar
10.16.2006, 08:28 PM
Okay, but that might take a while.
Nice to meet you!
squeeforever
squeeforever's Avatar
10.16.2006, 08:33 PM
Why? Plug it in and run it a few feet and see if it works...
captain harlock
RC-Monster Captain
10.16.2006, 09:02 PM
I still need to solder some connectors in it, Squee.
Nice to meet you!
captain harlock
RC-Monster Captain
10.17.2006, 12:04 PM
Well, here's what I have:
I have not tried the 9918, yet, but I tried the truck with the schulze controller one last time with some fixing and so on.
Performance is way better now, but still, there is a slight cogging which Mike told me that it can be done with a smaller pinion.
Also, do you think that a smalller pinion will be better for the motor and controller?
Now that the Slipperentials are around the corner, I believe using a smaller pinion is much better, right?
When Promod made his 50mph speed run with the Lehner XL1600 motor, he actually used a 12T pinion with a center diff which has a 51 spur.
Well, the 1950/10 is surely much stronger, but the controller wont be able to handle a large, heavy, steel 24T pinion.
My pinion is two times as big as Promod's. If he used my pinion with XL1600, I'm sure that motor would not have lasted for long enough.
I think I should go for 18-20T pinion to be in the safe zone.
Nice to meet you!
tallyram
tallyram's Avatar
10.17.2006, 03:09 PM
that should be ok. i run a 1950/8 and 6s lipo, with 18/51 gearing i get around 50mph. i use a g2r.
  Send a message via AIM to tallyram
captain harlock
RC-Monster Captain
10.17.2006, 03:15 PM
Your truck seems light. The motor you're using is quite fast, too.
How fast will my truck go, you think? with a 1950/10 and 51/20.
Nice to meet you!
tallyram
tallyram's Avatar
10.17.2006, 03:35 PM
what truck is it in?
captain harlock
RC-Monster Captain
10.17.2006, 04:01 PM
Here:
Nice to meet you!
squeeforever
10.17.2006, 05:07 PM
Remember, Tallyrams truck has stock ratio diffs, were as yours as 3.31:1 diffs...
captain harlock
RC-Monster Captain
10.17.2006, 05:30 PM
What's the gear ratio of his truck?
Nice to meet you!
tallyram
tallyram's Avatar
10.17.2006, 06:45 PM
stock maxx and revo diff ratio is 2.85/1! hope this helps.
captain harlock
RC-Monster Captain
10.17.2006, 08:02 PM
No wonder you're fast.
A center diff or a slipperential will add more speed, right?
Or is it just about handling?
Nice to meet you!
tallyram
tallyram's Avatar
10.17.2006, 08:24 PM
i'm not sure on that one.
squeeforever
10.17.2006, 09:47 PM
No....It won't add speed....Just handling...You have to compensate for gearing when you change diffs or whatnot...
Promod
10.18.2006, 12:29 PM
A center diff will give speed maybe not directly. There is less drivetrain drag with a center diff but not sure how much this helps in speed.
The center diff will give you the ablity to run a very high gear ratio. Much higher than you can get with a trans. Which equals higher speed in low rpm set ups. The best gain with the center diff is it will keep the front wheels on the ground(mostly:027: ).
That 1950/10 on 6s is what I would call a low RPM set up and will need a tall gear to get speed. Just keep adding gear to it and watch your temps. If it cogs your pulling the trigger to slow:) .
Thank you,
Promod
