12.06.2006, 10:58 AM
Originally Posted by t-maxxracer32
...i do have an off the topic question.. i have these 2 crazzy 3000 packs (6 cell) when i get my brushless i will never use these cause well... itd be pointless i have 3 gp3300s(that im going to convert each into 8 cells) and i have 2 ib3800s. so my question is what would happen if i took these 2 packs and made one? idk if id have to solder them together or what. but it would just be a fun pack to play around with. would it become a 14.4 3000 pack? or 14.4v 6000 pack? not really sure how that works
thanks guys!
I don't know if this is what you meant, but I wouldn't mix the batteries (GPs and IBs). As far as making a big 14 cell (or other cell count); it works fine. I have a single 14 cell GP (from RadioShack) pack for my Revo. I basically took two 7 cell rows and put them on top of each other to form a "brick" pack. If you keep the packs seperate, you have to use a Y adaptor to hook them together. But if they are all in one pack, you don't use a Y connector, just the bus bars between each cell. Less connectors and wiring means lower resistance.
If you hook all 12 cells in series, you'd have a 14.4v 3300mAh pack. Series adds the voltages, parallel adds the current.
t-maxxracer32
t-maxxracer32's Avatar
12.06.2006, 05:54 PM
no i mean that i have 2 of the same 3000 packs. they both arre 6 cell and both suck. imthinking about combining them to make one 12 cell pack.
lmkhow that would work! gimme a link to the y adapter?
thanks!
