jhautz
jhautz's Avatar
02.15.2007, 07:35 PM
Originally Posted by Sower
The challenge with the Quark for me is the value. It's expensive, and needs fans and a heat sink. I guess it's just tough for me to buy it when the MM is so close to being it's equal, costs 1/2 as much, and is so easy to program.
Heatsink yes. I think that it is ''needed'' The fans are not really needed. From what I have found the fans are a little overkill with the heatsink. I run the Quark in my XLB conversion with just a heatsink and it stays cool enough. Never thermals or anything. The fans just keep it really cool.
I wouldnt exactly call the MM its equal. The MM is a reliable 4s controller and the Quark is a reliable 5s controller. Yes the MM will run 5s, but about as well as the Quark runs 6s. Its pushing it. The MM only runs 2 pole motors. The quark will run any motor. (Even outrunners) The MM needs fans in larger scale aplications also. Most that run it in monster trucks or truggies need fans to keep the temps down. (EDIT: The Quark is still a much smoother esc than the MM even with 2 pole motors. The MM in my experience still has a slight cogging with the bigger 2 pole motors like the Lehner and Feigao motors. The Quark just doesnt cogg at all.) The only real advantage the MM has over the Quark is the USB programaing. And in my opinion how often do you really program the thing. A few times when you get it to try out different settings to see what works for you and then you pretty much just leave it. So that advantage doesnt loom that large in my mind. I cant remeber the last time I changed any of the setting on my quark. Once its setup it just works.
It really boils down to whats good enough for you and what your budget is. I'm not tring to bash the MM here. I think its amazing for the $$. I am talking about what the best setup is. IMO the Quark with any motor is still the best setup. I personally am willing to pay for it cuz I know it just works, its reliable, and I dont need a second controller in case the first one fries.
to make it...
or break it...
Silent...But Deadly
AAngel
02.15.2007, 07:38 PM
Yeah,
I'm sticking to the MM camp myself. Just running my MM with the Feigao 7XL, the smoothness is more than adequate. I didn't build the rig to go slow. I don't mind a tad bit of cogging that doesn't render the car into a state that needs physical intervention. I can get the MM/Feigao to cog if I try. Under normal driving is either doesn't happen or is not noticeable.
If the Lehner is as much motor as the Neu is, then I'll just go for the Lehner and hope that I never have to send it in for repairs. I'll just get it from Mike, and forego the price shopping. I'm starting to develop a sort of loyalty to his shop and if I do ever need repair work, he might be able to expedite things for me.
BTW, I'm going for the 1940/7. I thought about the 1950 series, but I think it's going to be way over kill. I've read of guys running 1930 series in monster trucks and having really good results; besides, my Feigao runs fairly cool. The Lehner should be better. BTW, will I notice a performance increase by going with the Lehner?
Will the RC Monster heatsink fit onto a 1940.
GD, I think I read someplace that the Lehner motors are no longer reconfigureable. Not a big deal to me, but if I'm wrong, it'll be a plus.
Sower
Sower's Avatar
02.15.2007, 07:40 PM
I wouldnt exactly call the MM its equal. The MM is a reliable 4s controller and the Quark is a reliable 5s controller. Yes the MM will run 5s, but about as well as the Quark runs 6s. Its pushing it. The MM only runs 2 pole motors. The quark will run any motor. (Even outrunners) The MM needs fans in larger scale aplications also. Most that run it in monster trucks or truggies need fans to keep the temps down. The only real advantage the MM has over the Quark is the USB programaing. And in my opinion how often do you really program the thing. A few times when you get it to try out different settings to see what works for you and then you pretty much just leave it. So that advantage doesnt loom that large in my mind. I cant remeber the last time I changed any of the setting on my quark. Once its setup it just works.
Very good points. I guess you're right about the frequency of programming. Not sure why I didn't think of that sooner. I had a Quark 33 in a Mini-LST and a XXX4 G+ (I guess you knew that one) - and you're right. Programmed it once and that was it. I think I'm back on the Neu/Quark setup.
This message board rocks.
AAngel
OK, here I go second guessing myself again. If I get a performance increase with the Lehner, should I go with the 1940/7 or will the 1940/8 have performance similar to the 7XL?
jhautz
jhautz's Avatar
02.15.2007, 07:43 PM
The 1940/7 is a wicked motor. You will love it. And yes the RCM heatsink will fit it.
Try the 1940/7 on 5s if you really want a kick in the pants. Its jaw dropping.:p
to make it...
or break it...
Silent...But Deadly
Sower
Sower's Avatar
What vehicle are we talking about here? Monster truck, truggy, buggy . . . ?
jhautz
jhautz's Avatar
02.15.2007, 07:46 PM
jhautz . . . dude, I just checked your photo album and saw my old Neu powered XXX4 G+!! That brought back memories - very cool.
Sorry all of you for that tangent. I'll stay on topic. :eek:
:018: Yea, That was a cool little buggy.
to make it...
or break it...
Silent...But Deadly
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.15.2007, 08:02 PM
I would say 1940/8. After what you saw with the 7xl... saying it's almost too much, etc... do you want to go with the same kv again in the 1940?
Now is your chance to drop the kv a bit...
7:2239kv
8:1959kv
The 1940/7 is very close to your 7XL.
I don't know how much the actual performance will be different going to a 1940... should be about the same, just more efficient.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
riceman
RC-Monster Gold
riceman's Avatar
02.15.2007, 08:12 PM
Just more food for thought. I'm joining this thread a little late but thought I would throw my experience with the MM and Neu 1515 1Y combo in an LST2. I've been running this setup for about 5 months now without any major issues. What I once thought was cogging was actually my brakes binding and causing stuttering. Believe me when I say this truck has been run hard and has had it's share of nasty crashes. The MM has even been ejected and dragged by it's wires a couple times. The only issue I had has been posted here and has to do with LVC settings on 5S. This video clip is pretty typical performace. on 5S. I couldn't be happier with my setup. Would I recommend it? Not without mentioning issues others have had here. With that being said I will be doing a CRT conversion soon myself... MM/Neu
BigSushi
02.15.2007, 08:35 PM
I think you guys should check with Mike. I called him up and told him I already have the MM for my E-Revo and asked what motor he suggested and HE recommended the Nue 1515 2.5 and that is what CC was recommending as well - according to Mike. Reading this makes me a tad nervous since I have not finished my project but have a nice $280 motor sitting there on my bench waiting for a few more parts to complete the project.... fingers crossed!
glassdoctor
TEAM FUSION
02.15.2007, 08:44 PM
There seems to be conflicting info coming from CC. When the MM was first out Shawn was recomending the Neu. Now it depends on who at CC you talk to... some don't seem to know there is an issue, and others act like it's common knowledge.
It seems to me that the recomendation of hte Neu is based on how good the motors are, without actual experience running them in cars.
I'm sure the Neus are great in the planes... but remember the car thing is relatively new to CC... they are still what I would call plane guys.
Edti:
But, they are slowly coming around... and the Mambas are becoming a larger % of their business every day. A couple years back they were 100% planes... now it's more of an even split. If they play their cards right, the company could be car dominated in the future.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
AAngel
02.16.2007, 02:34 AM
OK, I have to quit thinking about this for a while. I'm changing my mind like my wife does. We finished my buddy's buggy tonight. Well just about. We got the battery tray figured out and we're hoping that his MM and 8XL show up tomorrow. After running the 8XL, I'll see if that's the route that I want to take, speed wise.
I was getting ready to pull the trigger on the Lehner, but then I remembered the 4mm shaft.
I may just order the Neu and just live with what I get. If it cogs too badly, I'll just put it aside and wait for Castle to do what they have been promising to do. I'm still liking the 1515/1Y, and that's only because it's the only motor they offer that is in the ballpark kv that I want to be in.
AAngel
02.16.2007, 02:38 AM
Oh, I don't know if I got the answer to this, but will the RC Monster sink fit the Neu smooth can motor? Does it even need a heat sink? If I get the finned model, will I need a fan? I'm just asking because, if I need a fan, I'd just as soon use the RCM heatsink that I've already attached a fan to.
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
02.16.2007, 02:44 AM
no, it will not fit, the smooth nue is ~39mm while the heatsink/clamp is made for the "normal" 35.8mm motors.
losi 8ight-t
xray xt8
Cartwheels
02.16.2007, 02:47 AM
One other thing to consider is that batteries also seem to make a difference in the cogging with the MM/Neu combo. I have an older Kokam 4s 3200 mah pack that seems to make the system cog a lot more than newer Lipo packs that are coming out now.
The MM is a great little system but, I think I'm with jhautz, I like the Quark for the 1/8 scale stuff right now. That may change though. Hopefully sooner rather than later if CC can do a programming fix.
