Go Back   RC-Monster Forums > Support Forums > General Nitro
Daniel Murray
Talking 07.08.2005, 09:59 PM
Originally posted by RC-Monster Mike
I know the hyper engines run very well and also hold a tune very well. I will strap the .27 into my truggy and break it in this weekend if I get the time. I wil let you know how it goes!
Thank you and let me no!!! If you can compare it to other engine so I may know how it is.
Also would you say the head is as big as .247 head or sportwerks,or a wasp just so I no the size? It just looks small to me?
Thanks again Mike
Daniel Murray
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
07.08.2005, 10:04 PM
The head is smaller tha the .247 pro head for sure. It is about the size of a regular .21 head.
Daniel Murray
07.08.2005, 10:07 PM
Do you no who makes the engine for them or is it theres?
RC-Monster Mike
Site Owner
07.08.2005, 10:10 PM
Team Infinity makes the motors, as far as I know. RDLogics distributes and sells them.
squeeforever
squeeforever's Avatar
07.08.2005, 11:47 PM
so which would be the better of the two? the tm or the tz?
Daniel Murray
07.09.2005, 12:17 AM
The TZ Makes 2.3HP and the TM makes 1.6HP
Daniel Murray
Talking 07.09.2005, 10:54 PM
Mike you said you can get Picco? how about OMEGA X3 PICCO .26 ENGINE W/PULL START
The specs. seem good
PICCO .26
- ENGINE SPECIFICATIONS -
CLAIMED HP 2.7
RPM 37,000
CARB TYPE SLIDE
CRANK SG/Threaded
CONSTRUCTION ABC
ENGINE CASE SIZE .21
ENGINE BORE SIZE .26
TYPE REAR EXHAUST
PORTS 7 ports
DISPLACEMENT .26 c.i., 4.27cc
CRANKSHAFT Heavy Duty Crankshaft 14mm
CARBURETOR Composite, 8mm insert, changeable
PLUG TYPE Standard
Could you get this engine and how much?
OR
Hyper .21 8 Port Race
PART #53218
CLAIMED HP 2.7
RPM 38,000
CARB TYPE SLIDE
CRANK SG
CONSTRUCTION ABC
TYPE REAR EXHAUST
KEY FEATURES 14mm inside bearings and larger crankshaft
Thank you ,
Daniel Murray
RC-Monster Mike
Site Owner
07.09.2005, 11:59 PM
I can look into the prices on those motors, but the hyper 8 port race motor doesn't have a pullstart(which you need if I am not mistaken). I have the hyper 8 port with the pullstart in stock already. The picco is a good motor as well, with gobs of torque(a buddy of mine runs it in his truggy). I will find out about the prices for you.
Mike
Daniel Murray
07.14.2005, 07:55 PM
Mike did you run the .27 engine?
Daniel Murray
RC-Monster Mike
Site Owner
07.14.2005, 08:47 PM
Not yet, Daniel. Sorry! I have the clutch and header/pipe installed and ready to drop in, but I haven't had a free moment to strap it in and break it in. I promise it will be done this weekend. I plan on racing all weekend, so we shall see how the motor holds up/runs. I promise to get back to you as soon as I can speak to this motors performance.
squeeforever
07.15.2005, 11:19 AM
is it just me, or is the trx 2.5r impossible to keep tuned? mike, is this common? i was originally gonna replace it with something else, but the performance is great, for now anyway. also, what is the best pipe for the revo?
Daniel Murray
07.15.2005, 06:08 PM
THE trx 2.5r IS A PAIN IN THE A$$ TO TUNE AND KEEP COOL:devil
THAT IS WHY MOST PEOPLE GET RID OF THEM :p
squeeforever
07.15.2005, 09:14 PM
im finding that out. what is the normal operating temp? and also, what does it mean when you have to give it partial throttle to keep it running. im assuming that the idle screw need to be back out a little right? the only thing is, its fine after it warms up.
Daniel Murray
07.15.2005, 09:18 PM
Temp should be 220 to 250 but most traks that I see is like 275 to 350.Turn your idle up by you controler and when it is warmed up turn it down.Nothing big I see it all the time.:L:
squeeforever
07.15.2005, 10:03 PM
350?!? wouldnt that be considered over heating? traxxas says 270 is overheating.
