crazyjr
crazyjr's Avatar
06.17.2007, 02:07 AM
I am at my sisters this weekend and thought i'd run my T4 3s setup on the dirt road in front of her house, I figured the dirt would let me get to top speed easier with wheelspin (as opposed to blacktop traction). Well same story, even at 7/8 throttle, when i pull full throttle, the front jumps up and the back becomes a dirt scoop. So i need a few ounces in front for top speed runs
cool 2300 posts
coolrunnings
08.31.2007, 04:25 AM
I have had bad luck running higher kv motors, too much heat and damage.
08.31.2007, 09:57 AM
Running high kv motors can work provided that the right voltage is used to keep them from over-revving and proper gearing is used to help reduce the motor load a little.
Unfortunately, most people who want high speeds automatically assume they need a high kv motor. Then, they use too much voltage and gear too high creating issues.
