rootar
rootar's Avatar
01.31.2008, 01:57 PM
dual 7Ls on 3s would rip
jzemaxx
01.31.2008, 02:06 PM
Would the mamba max controllers be the best to use?? Or will the VXL3's be the ticket for the 3S limit? The mamba's though will take up to 4S correct?
jzemaxx
01.31.2008, 02:11 PM
I looked for the 7L's for pricing and don't see them listed. I am ready to order.....
squeeforever
squeeforever's Avatar
01.31.2008, 06:31 PM
The mamba's are no good for such a big vehicle. You need as a minimum L-can motors. Go for the Foam tires. Imex has them. Pizza cutters are very difficult to control and are very dangerous. A 10Lbs vehicle going 60+ mph will cause serious injuries and damage, when control is lost.
I would have to disagree. Two Mamba's in a MT will be more than enough.
I would go for either two MM5700 or 6900 setups using Komodo LP tires. There lightweight and won't balloon. If moneys no object though, maybe go with two Neu 1509's with a couple MGM 9012's.
Mod Man
01.31.2008, 07:00 PM
Also, there is no reason to run ceramics. I have run stainless bearings up to 90,000 RPM without problems. The ceramic bearing thing is a bunch of hype with very little basis. Focus on getting as much power to the wheels as you can.
Matt
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.31.2008, 07:05 PM
What is the distance that this "topend" should be achieved in?
Tashpop should be here giving you ideas how to get the topspeeds in a MT. He has been showing up at our drag race Test and Tunes with his beast and his goes fast.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Mod Man
01.31.2008, 07:17 PM
Line of sight for a 10th scale car is about 1000 feet. I try to get my car to max out in about 800 to 900 feet.
Matt
jzemaxx
01.31.2008, 07:40 PM
Total distance is 1320ft if you need it.
jzemaxx
01.31.2008, 07:43 PM
Well whoever can chime in to get me squared away would be great. I am ready to order right now and have my debt card in hand....lol. This event will be here before I know it so I need time to test with different spur pinion combos. I just ordered everything from 20T-24T and 62-52 so far for spurs.
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.31.2008, 07:50 PM
AAh, so it's a true quarter mile race. So do what Modman suggested, about reaching your "max" speed at 800-900 feet. You better have some beefy 3 cells man.
Mod Man
01.31.2008, 07:53 PM
Man, being tied to 3S really sucks.
I have trouble even running 12S!
Matt
jzemaxx
01.31.2008, 08:17 PM
Well its to have a large turnout. Most people can afford the 10 cell and 3S batteries. Also makes you have to tune the truck and know what your doing instead of just having the guy with the biggest wallet go buy twin Neu 1527's with twin 10S Lipo's....lol.
Mod Man
01.31.2008, 08:24 PM
I understand. But, it can get even more expensive when you limit the power system because now you have to get a high cost very high amp ESC and a crazy high KV to achieve decent speeds.
Speed is expensive, no matter how you try to limit it.
What is that saying? "Speed costs money, how fast do you want to go?"
Matt
01.31.2008, 08:25 PM
what about dual 6xls?
tashpop
01.31.2008, 08:27 PM
don't know that i can add anything here except if you're using rubber tires, run with some truggy tires, they seem to hold up to high speeds better. other than that, i did what mod man said, put as much power to the ground as possible. make sure the drivetrain can take it, although if your gearing high, you might get away with the lack of torque. using such low voltage pushing a large vehical fast, you better concentrat on an esc with very high amperage capabilities. your going to want as many watts as you can get and being stuck on 11.1v means really high amps. basically twice the amps that i'm seeing in my mgm160 since i'm using 6sa123's. make sure you get some batteries with a very high discharge, you don't want to over drawl them and loose motor speed from voltage drops.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
