zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.03.2009, 04:01 PM
I bought mine at aircraft-world.com... Mike said he is getting more configurations in soon (he really likes them).
Redshift had kinda reviewed the Hyperion Swift 20C packs and said they blew his FP 25C packs 'out of the water'... these are the same cells (same new cell chemistry/manufacturing process) as the Swifts... so if they are any indication, then I am wondering if they are actually all the same performance cells and they just label them differently?
But, if you want a 6s 25C 5000 pack, the pack resistance is 9.1mohm, whereas my 4200 3s 35C packs are 4mohm, so for 6s, times by 2, for 8mohm. Not much difference there. I would have gotten the 25C packs, but they don't fit in the E-revo batt compartments.
Here is the link where I got mine.
http://aircraft-world.com/shopdispla...-Po+-+HYPERION
zeropointbug
Z-Pinch racer
07.04.2009, 09:34 PM
Well, I already blew the rear differential out! I have had it for 2 years now, and as soon as I get these batts, POOF. I also don't have any spares, so it looks like it's a 2wd beast for awhile.
redshift
RC-Monster Square Tube
redshift's Avatar
07.04.2009, 10:48 PM
Welcome to the club ZP....
Shall someone start a thread dedicated to the damage done by the new gen packs??
Hyperion could have named the new packs better, someting like the "Driveline Tormentor Series" or even something more positive sounding like "The Wheelie Maker"
BTW my 4000 Classics are reading 9-10 mohms at charge start, and I guess zero at full.... not sure what to make of that as I am an idiot, but sounds respectable I guess?
So yeah guys, buy these packs and get ready to Shuck Fit Up...
zeropointbug
Z-Pinch racer
07.05.2009, 12:52 AM
9-10ohms, is that a 4s, 5s, 6s?
My 3s packs are reading between 4-5ohms when charging and discharging (rated 4ohms). 720i NET charger.
Funny thing is my 6s 4350mah 25C Enerland based Hyperion packs are reading 23ohm?? Does that make sense?
redshift
redshift's Avatar
07.05.2009, 09:11 PM
Classics are 2 cell.
zeropointbug
Z-Pinch racer
07.05.2009, 10:45 PM
Wow, and mine say 4-5ohm for 3s.... well, I wouldn't doubt it, they torture my transmission parts... at the track last week it blew the center CV cup off.
zeropointbug
Z-Pinch racer
07.15.2009, 09:22 PM
Aight, after a long wait from Eagletree about my non-working eLogger, I just went ahead and did a discharge test in LIVE mode with my laptop. So here we go...
Testing I used my electric 24V lawnmower on idle (just sitting there), as I figured it would be a pretty good constant load for the packs. Also, the loads are not that high, only 6C, but still, the purpose of this was to compare the discharge 'CURVES', the flatter, the better.
On test:
-6s Hyperion VX 25C 4350mah - Enerland based pack
-6s Hyperion VX 35C G3 4200mah - Unknown 'new gen.' based pack
Now you should note that I am pretty positive the current readings are off, as both of these packs only discharged 3823mah(4350mah rated), and 3950mah(4200mah) respectively.
The 25C pack looks to get 21.5volts average discharge.
The 35C pack looks to get 22.0volts average discharge.
Keep in mind that my eLogger is not accurate, and that actual voltages and currents will be different, probably higher. (me know it is) But for comparisons purpose, it is a good relative test.
I inserted a thin red line at 22volts for reference purposes.
HERE is the 25C Enerland based pack
HERE is the 35C G3 based pack
I hope to do some more higher discharge test to show more accurately what each pack is capable of.
Cheers
zeropointbug
Z-Pinch racer
07.17.2009, 11:56 PM
So flightpower listed the prices of their packs on the USA website, and the prices are not too bad, definitely not like what their cost difference used to be. I also noticed another thing, IF the test above is to be believed, and now I think it IS accurate, even the discharged mah, then Hyperion overrates their specs, as far as MAH CAPACITY is concerned.
Looking at the different batteries FP has to offer:
EON X30 3800mah 3s pack - 345grams - $130
Hyperion G3 4200mah 3s pack - 345grams - $100 (actual discharged ~3950mah)
Again...
EON X30 3350mah 3s pack - 279grams - $125
Hyperion G3 3300mah 3s pack - 279grams - $80
This goes for almost the entire range of packs that are close to the same capacity, so I am sure FP and Hyperion use the same manufacturer. Also, FP seems to underrate their packs(or more conservative, take your pick), less mah rated for the same cell pack, and a lower C rating as well. So, does this deserve a ~30%+ increase in pack cost for the same thing? Are FP's going to be better matched, better voltage holding ability? Does it really increase costs that much that the consumer must pay for extra quality, wherever it may be... whatever form it may be in?
I think I am going to purchase a pair of the 3s 3800 X30's soon, see how they compare to G3's, which are 25% less. Maybe a Zippy pack is in order too.
drkdgglr
07.20.2009, 05:40 AM
Some more numbers:
Ran my 6s2600mah35c pack today in a Mini Ste:
The setup peaked at 63,58amps and at that point voltage was 21,78v.
So at 24c the pack voltage was 3.6v. This was in the 6th minute of bashing.
drkdgglr
07.20.2009, 02:35 PM
eagletree graph of accelleration to high speed (in kmh) vs pack voltage
Photobucket
zeropointbug
Z-Pinch racer
07.20.2009, 10:33 PM
Oh thanks for posting that, I just noticed it.
23volts at topspeed, impressive. Your voltage drop is pretty much what I have with my 4200 pack, a tad over 20C at 3.7v/cell, that is for the first part of the discharge, then obviously it will be slightly lower as the pack gets discharged.
I would like to do some more tests myself in my Revo, however, my Eagletree only works in LIVE mode at the moment, unfortunately.
So any subjective opinions about the G3's you want to add?
drkdgglr
07.21.2009, 03:34 AM
Not really. haven't run any other packs in my mini ste to compare with. I would really like to test the 35c4s3300 packs in my 8s Muggy though. That would be pushing the packs more to their limits. I have 30c Neu packs in there now, and voltage drops to 3.2-3.4v per cell at 30-40c. My 25c pq packs dropped to 2.9v/cell (in the 8s Muggy) at those ratings and they dropped to 3.4v/cell at 18c (in a 8s Slash).
