glassdoctor
TEAM FUSION
glassdoctor's Avatar
08.22.2006, 03:31 AM
Don't want to stay off topic but..... :) I think we just won't see the same #'s in the truck as we see in the discharge graphs from the guys who test a bunch of batteries.
They are using heavy wires directly connected to a bare cell... no esc, no long wires, no connectors, fresh off the charger, etc etc
The maxamps 6000 packs "feel" better than any other packs I have right now, so I am sure the numbers from the others would be worse yet...
I am going to put together a big pack for the truggy for super long run time... I can't wait to see the data from those packs. I think the voltage will hold very very well with a 12000mah pack. :)
Serum
Serum's Avatar
08.22.2006, 02:09 PM
One thing that concerned me;
my maxamps 4000mAh packs came with thin wires; 14awg..
Thanks for the graphs, are you using the micrologger too?
glassdoctor
TEAM FUSION
08.22.2006, 11:42 PM
yup... new toy for me.
I think the Mamba Max comes with 14ga also. But high strand quality wires like this don't have much loss esp in just a few inches of wiring.
I know what you mean though... I have been using 12ga wet noodle for years and 14ga seems kinda small. But really, the 12ga may have just been overkill all these years. :)
MetalMan
MetalMan's Avatar
08.23.2006, 12:11 AM
The Mamba Max has 13ga. wires on the ESC, and the motors have flexible 12ga. wire.
glassdoctor
TEAM FUSION
08.23.2006, 12:29 AM
Are they that big??? :) oops I should look closer huh? I must have some big arse 12ga cause they look kinda thin... ha ha
08.23.2006, 12:51 AM
All wire has resistance. The shorter and/or smaller lengths have less. The shorter you have the wire, the smaller gauge it can be. If the wires needed to be like 10 feet long, we'd have to use 4 gauge for ~75A! Using smaller than recommended will just create more voltage drop and heat for any given length.
Serum
Serum's Avatar
08.23.2006, 01:22 AM
That's not overkill glass, if 12GA wire gets hot already, it's not overkill to use it. with that in mind, 14ga is too small.
glassdoctor
TEAM FUSION
08.23.2006, 01:36 AM
ok...14 is bad. that make me feel better. :) I think I was forgetting how small 14ga is... and assumed the MM smaller wire was 14. At any rate, Castle says there is no way those wires are an issue... that they are more than capable for what the systems can sdish out.
who gets 12 ga 1400 strand wire hot???
Serum
Serum's Avatar
08.23.2006, 03:15 AM
Yeah, they do use 12ga for the battery leads.. And a 1/10th setup is less current hungry than a 1/8th monstertruck
aqwut
Brushless Heavy Weight....
aqwut's Avatar
08.23.2006, 07:15 AM
I like deans wet noodle 12 gauge they work pretty good.... but they're are they a little bit thicker then deans utra 12 gauge. I try to use 10 gauge for everything.... I don't like it either when batteries comes with 14 gauge wires.. it just looks funny...
glassdoctor
TEAM FUSION
08.26.2006, 01:22 AM
I think what BG is trying to say is ummm... there are two ways (in this case) to skin a cat. :D
The reason they have motors in both delta and wye styles is simply to get more variety in kv ratings.... a wider range of #'s. There is already a big jump between some kv ratings even with both styles of wind. Such as the gap from the 2.5D 1700kv.... to the 1Y 2200kv in the 1515 line. If they only offered Y or D then this gap would be wider yet.
FYI... Some have claimed one or the other to be a superior method, but according to the Neu distributor, both styles are equal... they say one is not "better" than the other. So it doesn't matter which style you get. Just pick the kv you want.
Serum
Serum's Avatar
08.26.2006, 02:20 AM
Sounds like delta could have the potential to produce a bit more torque.?
GriffinRU
08.27.2006, 10:46 AM
It is hard to say, depends on motor, application and controller (true AC or mod. AC).
Check discussion here
In some cases in Delta is harder for sensoreless ESC to identify rotor position then in Star.
Artur
glassdoctor
TEAM FUSION
08.27.2006, 02:40 AM
Just a note that I tweaked the truggy a bit and did another quick midnight test run... trying not to annoy the nieghbors too much.
I'm guessing the top speed is kinda slow (I will check that tomorrow) but geeze this thing has serious torque. (Neu 1512 1900kv) Truggies are not supposed to pull wheelies are they???? :D
This may need a new thread... but part of the magic I think is the new lipo packs I soldered up today, using maxamps 4000 cells. I have a 4s 12000mah setup in it and it's incredible.
Pulling wheelies is getting +100A spikes and the voltage (fresh off the charger) was holding over 3.7v per cell. Lowest voltage recorded in the two minutes zipping around was 14.9v on a 107amp spike.
I think I will try making my 6000 packs into some 9000s and I may have to retract somewhat what I have said about lipo packs. eg lower rated cells are fine if you run a large pack... that you don't need to buy the latest and greatest 20C cells etc.
This is still true, imho.... however after seeing the punch this huge pack delivers I wonder if the TRUE 15-20c cells could have a bigger performance edge that I thought over the good value 10C type cells, if the size of the packs are similar.
Some aspects like top speed I doubt are affected much, but holeshot is very impressive with the near-zero voltage drop.
Anyway I will run this thing tomorrow and see what it can do.
coolhandcountry
coolhandcountry's Avatar
08.27.2006, 12:18 PM
Well i got one myself to try. I got a 1512 2.5d. It kind of surprised me. It has good power and pretty smooth. I don't care for open design. I mussed steering linkage so couldn't finish testing. I think they are pretty good motors so far.
Peace!
Country
Help support the
Rc-Monster
Buy here
