Pierre
Pierre's Avatar
11.17.2007, 03:26 PM
Humm
I love brushless revo conversion !
First French brushless forum :
http://brushlessmania.forumpro.fr/portal.htm
  Send a message via MSN to Pierre
Revracer
Revracer's Avatar
11.29.2007, 08:51 PM
it looks like the motor will hit the rear arm in hard landings? does it or is that just from the view i saw? does it hurt suspension travel?
Matthew_Armeni
Matthew_Armeni's Avatar
11.29.2007, 08:58 PM
It doesn't hit, although it is close. I'm running Mikes Motor heatsink clamp and that pushes the motor back a little further then if I weren't to run it but it still fits with no problems.
  Send a message via AIM to Matthew_Armeni
fromdaboz707
04.06.2008, 04:31 AM
what is a good motor for an e-revo
04.06.2008, 09:19 AM
What are you currently using?
Are you going electric from nitro, or starting from scratch?
Do you want to go BL, or just sticking with brushed electronics?
What voltage will you want to run/ how many cells/ what kind of batteries?
What is the weight of your rig?
Do you have any existing experience of electric/ BL?
Better to read the stickies and existing E-revo threads and do a little research, rather than just jumping onto a thread and saying "what am best motor?".....
fromdaboz707
Talking 04.06.2008, 02:49 PM
i have a revo 3.3 and i am doing nitro to electric and i have seen do many BL motors out on the market and i do not know what to get and i am goign to use old 6 cell 3800 i have it first then go get a 3 or 4c max amps lipo
04.06.2008, 07:43 PM
4cell lipo from somewhere other than maxamps would be best, depends on your budget though (4s = 4 cells, the 'C' stands for the packs amp rating EG: 5000mah 10c pack is able to put out 50amps in theory). Maxamps are good, good over-rate alot of their stuff.
Budget is your biggest issue to concider then before choosing your motor and esc, since there as several 4s lipo/12cell Nimh esc and suitable motors to choose from....
